Check engine light for #1 Glow Plug? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-11-2012, 12:52 AM
zeus77 zeus77 is offline
zeus77 is starting off with a positive reputation.
Hey guys, I have the check engine light come on and its driving me nuts. My truck is a 2006 F-350 Lariat FX-4 DRW with a 6.0 diesel. The code reader indicates the problem is the #1 Glow Plug. I changed out the glow plug today, cleared the fault code but the check engine light still comes on with the same fault code. The wiring harness appears to be pluged in securely. Does anyone have any suggestions on what the problem might be? thanks in advance. Zeus
Old 08-11-2012, 10:41 AM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Did you test the old glow plug with an ohm meter to see if it was really bad? If it is bad, it will be an open circuit, with infinite resistance. It will help to know if it really was a bad GP, or not.
Check this thread out. M-Chan68 gives a very good explanation on testing glow plugs.
http://www.ford-trucks.com/forums/11...ult-p0675.html
If they all test okay, then it is probably the glow plug control module. In fact, I think the GPCM failing is more common than the actual glow plugs. But I've had both fail on my '06, so it happens.
Will they fit???????? Zeus-FX4 1999 to 2016 Super Duty 2 08-24-2015 09:10 AM
fault codes pappy's powerstroke 1999 - 2003 7.3L Power Stroke Diesel 3 11-29-2014 09:57 PM
Check engine light? dannyg1992 1999 to 2016 Super Duty 4 07-25-2014 02:46 PM
1999 ford f350 7.3l idm issue? justinlb917 1999 - 2003 7.3L Power Stroke Diesel 45 05-24-2014 02:41 AM
glow plug monitor ? popkorn 1999 to 2016 Super Duty 1 09-14-2003 08:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
