Got my MBRP installed today
Finally got my turbo back MBRP exhaust installed today. I got the system that uses the cat since I'm in CA. My installer cut off the extra pipe off of the cat and was going to weld 4 inch piping going into and out of the cat, but once he got a look inside the cat, he discovered that the insides of my cat was disintegrated and large chunks were falling out. He didn't have a replacement cat in stock so in went a custom cat delete pipe. I guess I'll have to worry about it once smog time comes.
I must say, the sound of the turbo is downright ridiculous!!!! The exhaust really woke up my truck and if my foot isn't in it, it's kind of like stock...with the exception of the turbo whistle.
Does anyone know if a plugged/disintegrated cat is something out of the norm on a diesel? I didn't really notice anything wrong with my truck before the exhaust install.
I would knock the guts out of it and install it, problem solved. I could be wrong but I know plenty of people out there that have done that, and on a diesel it is not like it really does a whole lot. I was surprised that my 2000 calif emissions Excursion does not have a cat on it. I checked and yup it says no catalyst under the hood.
the one ( that I may or may not have seen done) was on a 6.0 diesel truck, on that one he cut the ends off close to the ends of the cat and set it on a trash barrel and used a air chisel and a foot long chisel in it, after hitting it in a few spots it pretty much fell out, you have to be careful to not hit the outside of the cat too many times or it will look like it was beat from the inside out... it took less then 2 minutes total. he then used the cat delete pipe section of the exhaust kit and welded it cleanly to the ends of the "cat" housing. (He was installing a 4" Diamond eye kit at the same time.)
I think I might just do that once I get my cat gutted.
