Anyone in the Henderson/Las Vegas area? - Ford Truck Enthusiasts Forums
Old 08-10-2012, 07:52 PM
turnkyle turnkyle is offline
turnkyle is starting off with a positive reputation.
I am living in Henderson, NV at the moment and want to do the six litre tune up on my truck. Most of it is pretty easy other than adjusting the timing. I have never done the timing on a vehicle before so I thought I would see if there was anyone on here in my area with a timing light that would want to help me out.
Thanks
Old 08-11-2012, 07:28 PM
Nobody? I was hoping there would atleast be one person on here. You sure don't see to many of these trucks running around here though.
Old 08-12-2012, 01:54 AM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Well if you cant find anyone setting timing is rather easy. Climb under the truck and mark 10* BTDC on the harmonic balancer. Then mark 13* in a different color. Then go up to the top and mark the needle that sticks out over the harmonic balancer. Once all those are marked hook up the timing light like instructed in the timing lights instructions. Test and see where your timing is with the SPOUT connector removed. Should be 10*. To advance the timing, shut off the motor, loosen the distributor hold down clamp, and rotate the distributor VERY SLIGHTLY clockwise. Then fire it up and check timing. I set mine to 12.5*. Once set, tighten the hold down clamp and reconnect the SPOUT. Thats it.
Old 08-12-2012, 09:44 AM
Thanks for the advice. I have heard the timing is pretty easy to do, I just don't have a timing light. I wonder if checkers or autozone rents them.
Las Vegas/Henderson Diesel Shop Shad034 Nevada Chapter 9 03-05-2014 03:03 AM
Las Vegas/Henderson WVO Sunnshhinecrime Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 09-07-2012 11:04 AM
7.3 Insanity in Nevada *Now have CODES CosmoStarr 1999 - 2003 7.3L Power Stroke Diesel 4 06-01-2011 02:58 PM
Remote Start Installer in Las Vegas/Henderson Nevada? ddlv Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 01-20-2009 09:48 PM
1986 F-250 XLT Lariat 4x4 7.5L laughingman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-09-2005 12:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
