'96 F150 Ext. - Left Rear Speaker Install - Ford Truck Enthusiasts Forums
Old 08-10-2012, 07:41 PM
RBrasher RBrasher is offline
RBrasher is starting off with a positive reputation.
How, in God's name, do we remove the side panel to install a new left rear speaker in an F150, Extended cab? There is no rear door on the left side. We had no trouble installing the front speakers and the rear right speaker, but have no clue how to approach the left rear. Any help is greatly appreciated!!
Old 08-11-2012, 12:14 AM
Muddy701's Avatar
Muddy701 Muddy701 is offline
Muddy701 is starting off with a positive reputation.
There are no rear doors on the left or right side of 1996 model year extended cab Ford F-150's. You more than likely have a 1997 model year F-150 built in 1996.
Old 08-11-2012, 12:36 AM
Quote:
Gee, thanks, Muddy. That's what happens when I listen to my husband and don't look at the documentation myself. Not really the point though...
Since I'm asking about the side that doesn't have a door anyway, it doesn't much matter if there's one on the other side or not, eh?
How 'bout some help with the real problem at hand??
Old 08-11-2012, 01:28 AM
Muddy701's Avatar
Quote:
Well, I've never put speakers in a 97-03 F-150, but looking at a picture I found and experience with other trucks, I think you're going to have to remove the rear seat, then unfasten the front and rear seat belts from the points that are in the way of removing the panel, remove the flip out window latch from the panel, unfasten any screws helping holding the panel on, then pop out all the plastic pins holding on the panel. I also cannot stress enough keeping track of the parts you remove lol. I hope that will help you some.
Old 08-11-2012, 01:44 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
you would have better luck in the 97-04 forum then this one the 87-96 as the trucks changed completely between the two generations
Old 08-11-2012, 09:51 AM
Quote:
Good point! I put it here because I was told it was a '96. Will move it over there. Thanks for pointing that out!
Adding Rear Speakers w/ Base A/M-F/M Radio- 2005 F-350 Supercrew 05f350supercrew Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 04-16-2016 10:21 PM
88 f150 single cab rear speakers Rusty72782 1987 - 1996 F150 & Larger F-Series Trucks 3 07-19-2014 03:53 PM
Speakers in the doors John R. Thomas 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-14-2014 02:39 PM
'97 Ford F-150 - LEFT rear speaker replacement RBrasher 1997 - 2003 F150 2 08-13-2012 01:53 PM
2005 F-150 King cab rear speaker help asand211 2004 - 2008 F150 4 04-22-2012 06:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
