DEF sensors screwy???? - Ford Truck Enthusiasts Forums
Old 08-10-2012, 04:29 PM
hay is for horses hay is for horses is offline
hay is for horses is starting off with a positive reputation.
Going to haul the horses to a show and scrolling through menu and notice that the DEF says below 1/2 full. Roll into local ford delaership and buy 21/2 gallon jug and truck only takes 1 gallon?????? Service manager comes out and checks level in the dash and DEF says ok so it is good to go??????. My marth tells me this is a cab chassis and should have a 6 gallon tank so below half shoud have easily taken the 2 1/2 gallon. Truck pulled 16,000 pounds for 7 hours and def stills says ok any ideas???
Old 08-12-2012, 09:11 PM
no comments from anyone????????????????????
Old 08-13-2012, 06:55 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
It's not an exact science, def tank and all....
Old 08-13-2012, 08:56 AM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
I will put it this way, they got a mind of there own.lol
Old 08-13-2012, 07:32 PM
TRENT310's Avatar
TRENT310 TRENT310 is offline
TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.
In the DEF tank, there are just 3 contact points that measure resistance relative to a 4th common contact at the bottom of the tank, and that resistance value changes when various points are submerged. It's not a calibrated tank level measuring device. I go through the system check screen periodically and refill whenever it says less than 1/2 full so I never have to run it down to empty... that's all it's for. It's not for telling you how many gallons/litres you should add to the tank.
You're saying your truck says everything is OK, and you've been driving it and it has been working so I feel that there isn't really a problem here... heck if the DEF level never dropped at all and everything still worked fine I'd be okay with that.
It's almost like the windshield washer fluid tank. It's not really a concern as to how full it was, as long as you stop adding to it when you see the fluid coming up the filler neck, and now it is full. I top that up periodically as well and I don't care what level it was at before or how many litres I was able to put into the tank. I top up DEF just like washer fluid so I don't get the big fuss about it. I kept the OEM filler hose which seals great and I never lose a drop of it anywhere.
Old 08-13-2012, 09:52 PM
sgrol sgrol is offline
sgrol is gaining momentum as a positive member of FTE.sgrol is gaining momentum as a positive member of FTE.
FWIW - First, and only, time my message said less than half full I thought I would dump in 2.5 gallons and it only took 2.
Old 08-14-2012, 01:49 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Depending on your use, you have to run it for a bit with it reporting under half then an entire 2.5 jug will fit.
Old 08-14-2012, 05:41 AM
thanks for the replies. Maybe I don't have an issue but the 2 times i have filled the truck it said 800 miles to empty and only took 2 gallons and this time it was saying half empty and took only a gallon. Keep in mind this is a cab chassis that has a 6 gallon def tank. Worries me a bit as I travel long trips loaded with horses and it is usually in isolated areas and at night
Old 08-14-2012, 02:07 PM
BCM's Avatar
BCM BCM is offline
BCM is gaining momentum as a positive member of FTE.BCM is gaining momentum as a positive member of FTE.
Sensors maybe wired in the wrong order. Have your dealer check it.
Old 08-14-2012, 02:23 PM
720Deere's Avatar
720Deere 720Deere is offline
720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future
As a cab & chassis model, I would suspect that there is an issue with how the DEF fill hose is routed with your body. It sounds like you have have an issue with the fill tube getting air bound and not allowing you to fully fill the tank.
As was stated earlier, they do seem to have a mind of their own. Mine is not all that consistent either. I usually run it down to about 200 miles to empty, dump 1 full jug in then drive another 500 miles before dumping the second jug in. Sometimes it takes it all, sometimes it doesn't. The miles to empty is simply a guess since the truck has no way to actually monitor how much DEF is used and driving & atmospheric conditions differ constantly affecting your usage rate.
DEF Half full, Truck went into 500mi Countdown Nipperdog 6.7L Power Stroke Diesel 21 10-08-2016 03:43 PM
Odd DEF Problem chperry 6.7L Power Stroke Diesel 1 09-30-2014 06:14 AM
First DEF fill issues???? hay is for horses 6.7L Power Stroke Diesel 17 02-24-2012 11:43 AM
DEF Tank not reading correct Painted Horse 6.7L Power Stroke Diesel 17 09-09-2011 10:38 AM
Got my free DEF fill.....kinda Tacswa3 6.7L Power Stroke Diesel 7 02-26-2011 09:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
