88 460 no spark - possible wiring - Ford Truck Enthusiasts Forums
Old 08-10-2012, 09:16 AM
VBMECHANIC VBMECHANIC is offline
VBMECHANIC is starting off with a positive reputation.
Just bought an '88 F350 460 that didn't run. Although there are a number of reasons for this, I'm trying to tackle the problem of not having spark. The first thing I did was buy an ignition module (TFI). I know how problematic they are and figured that I'd want a new one regardless. No joy. After doing some research and having some fun with my test light, I discovered that there is no blink the negative side of the coil. There are 2 wires coming from that terminal. One goes straight to the TFI and the other goes into some inline box that looks like a fusible link on steroids with 2 wires coming out the other side that go back toward the passenger compartment. WHAT IS THIS BOX? It has a rubbery exterior with a squiggly line symbol on it. I disconnected the distributor and TFI plugs and hooked a ground wire to the negative coil terminal. I then checked each wire on the other side of the mystery box and got nothing. I checked these wires for any kind of signal (+ or -) while turning it over and nothing. I haven't traced where they go exactly.
I've already found a couple of wiring problems in the truck, so I'm not only trying to figure out if there is a component bad, but if any of the wiring is faulty. I don't want to clip out the mystery box and splice the wires until I know what the thing does.
Also, Anybody know how to test the stator in the distributor? If the wiring checks out, that's my next area of focus.
Thanks!!!
Old 08-10-2012, 09:26 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Did you look at the cap/ rotor, plugs, wires, COIL WIRE?
Old 08-10-2012, 09:28 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
That item is a 22K ohm resister and a 1.8K resister. The two wires leaving are the IDM (22K) wire going to the computer for information only and the other wire goes to tachometer (1.8K) in the cluster.
Old 08-10-2012, 09:48 AM
Electricity runs in a stream. The best way that I've figured out how to test electrical problems is from one end or the other. As best as I can tell, The flow of electricity from the end to beginning goes as such - plugs, wires, cap, rotor, coil, ignition module, distributor stator....and from there, I don't know. The problem is upstream of the coil, so to answer your question, Yes. I get a constant positive to the coil. There is continuity to the TFI (ignition module) from the negative side of the coil. The TFI is new. There is another wire from the negative side of the coil to an inline box. I don't know if the electricity streams from the coil to this box or to the coil from the box. Both wires from the box go toward the engine compartment. I'm going to find where they go, though. I know that there has to be a computer somewhere in this stream but I don't know where it connects. I also need to check grounds to each component in the stream. The specific question in this tread was to find out what the inline box does and it would save me some work if someone knew where the wires from it go.
Old 08-10-2012, 09:50 AM
Subford....THANK YOU sir!!!!
I'll post my progress.
Old 08-10-2012, 10:03 AM
subford's Avatar
You may want to unplug the computer while trying to get the spark to return.
This does two things.
1. It keeps you from dumping any fuel in the engine without spark.
2. It may let the spark return if a bad computer is keeping it from having spark.
Old 08-12-2012, 02:56 PM
Subford, I think you're quickly becoming my new best friend. I went and picked up a Stator for the distributor. It looked original so it was time to change it anyway. Still no coil pulse. Then...I unplugged the computer. Suddenly, I have spark!!!
So now, I have to wonder if the problem is the computer itself or if there is something sending an incorrect reading to the computer that is causing it to go into shut down mode. My fuel pumps aren't working either. I know that there is a short going to the pump in the tank but there is no problem with the wiring to the booster pump on the frame. It SHOULD be working but isn't. IF the computer is in a shutdown state, could it shut down the pumps and distributor? If I assume the computer is good, what could cause it to do that?
Old 08-12-2012, 03:16 PM
subford's Avatar
If you have power on pins 1, 37 and 57 with the key on and grounds on pin 40 & 60 at the computer with no pins pushed out in the plug then I would say you have a bad computer.
Old 08-12-2012, 03:25 PM
So you say that I SHOULD have power and grounds to the pins you mentioned. If not, I have a bad computer. Am I correct?
Old 08-12-2012, 03:44 PM
...also, there are no pin numbers on the computer or the plug. There are 60 pins total arranged in groups of 10. 3 groups on one side and 3 on the other. I'm assuming that pin 1 would be at the top left corner of the computer when the designation sticker is facing up. Do the pin numbers run straight across (1-20, 21-40, 41-60) or down (1-30, 31-60)? Making a mistake here would give me a false result.
Old 08-12-2012, 04:04 PM
subford's Avatar
Ford did not put a pin-out in the 1988 wiring diagrams so I will post two from the 1990.
They should be close to the same:
Old 08-12-2012, 04:05 PM
subford's Avatar
Quote:
You are correct.
Old 08-13-2012, 05:30 PM
I found no ground signal at pin 40. I traced the wire to the temperature sensor which appears to be new. The other wire from the sensor goes back to the computer to pin 7. I tried backfeeding the ground at pin 40 and I got spark for a moment. Then nothing. I left for a couple hours and came back to it. plugged it all back together and I checked pin 40 again to find a ground. Cranked it and had spark. After a couple tries, the ground signal vanished and no spark anymore. They seem to be related. I tried jiggling the harness to see if there may just be a bad connection somewhere but I got nothing.
Old 08-13-2012, 06:02 PM
Truckin Bob Truckin Bob is offline
Truckin Bob is gaining momentum as a positive member of FTE.
Here you go.
Click this link:
A9x ECM's (and same years ECM's) Failures Due to Age
If you see the "leaking capacitor" thing happening and you're handy with a soldering iron, give it a shot.
I repaired my computer for about 5 dollars.......parts available @ Radio Shack
If you see "mass destruction"......burnt chips, circuit board, and the like, just get a re-manufactured one or one from a bone yard.....of course open up the bone yard one and give it a visual check before installing too.
Good Luck !!
Bob
Old 08-13-2012, 06:22 PM
subford's Avatar
Pin #40 goes to the "NEG" (-) post of the battery.
There should be a black wire with a green stripe leaving the NEG post of the battery and going through a one wire in-line connector that loos like a fuse holder, this is the other end of pin #40 and #60.
This wire has been the problem on a lot of 1988 F-series trucks.
Parasitic Battery Drain- Still There freevan 1968-2013 Full Size Vans 9 09-12-2016 01:15 PM
Adding a aftermarket tachometer to my '93 F-150 Rockworthy 1987 - 1996 F150 & Larger F-Series Trucks 5 08-15-2015 09:24 PM
What year did Ford go to TFI on 460? 73FOMO Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 08-21-2012 04:26 PM
How do you set the ignition timing on a TFI IV distributor? mxhowes1 Ford Inline Six, 200, 250, 4.9L / 300 10 11-11-2011 08:39 PM
Wiring Diagram and Spark Help Needed '84 E150 4.9 mxhowes1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-03-2008 10:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
