Air shocks for the front?
Since the diesel swap, the front of my 69 F250 has been settling, and has gone a bit further than expected. It needs shocks anyways, so I was thinking maybe air shocks. It already has really heavy springs but the engine in it weighs a good 500lbs more than an FE, so even they aren't quite up to it.
Does anyone know what air shocks would fit this application?
I wouldn't recommend air shocks unless you plan to beef up the factory mounts. Most shock mounts are not designed to support the weight of the vehicle and can/will fail if put under a serious load.
Your best route is to use a spring to get you where you want first, particularly if it is a constant weight like an engine. If it is a removable weight, such as a plow, I always suggest air bags for their diversity.
Airbags might be a cheaper route for you to try though if a new set of coils is going to be way too stiff, or too tall. The kit we would offer for your application is 80590. I should mention, this kit would only work for 2WD.
Air shocks are not listed for the front in the 1964/72 & 1973/79 Ford truck parts catalogs, only "Auto Flex" "Auto Flex H/D" "Superflex" & 1973/79 (only) "Sure Trackers"
Air shocks are listed for the rear in the 1973/79 catalog. All these Auto-Lite/Motorcraft shocks, as I recall, were made by Monroe.
Thanks- This truck had some very heavy duty springs up front when I got it, it had a 300lb PTO winch hanging off the front. With that off, the truck sat really nose high, and when I first dropped the 7.3 in it sat about where it should have but has settled since then, so I'm not sure if bigger/beefier coils would help. Plus, I have a 60gallon fuel cell that is getting mounted at the front of the bed, that weighs over 100lbs by itself and fuel is about 7lbs per gallon- That's a potential swing of 400lbs that will have some influence on the front axle weight as well.
The air springs do look good and are a lot less than I expected. I may have to go that route. Plus, I am planning a three-link rear suspension with airbags and will need on-board air to run that. The stock leaf springs are not up to the torque this engine makes, even with a really good set of high GVW springs, it has horrible axle wrap.
lutarious
21
06-29-2017 11:48 PM
KrautBurner
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-23-2011 12:54 AM
Mountaineer40
10-08-2004 07:41 AM
