16" half ton rims.....? - Ford Truck Enthusiasts Forums
Old 08-09-2012, 10:24 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Taught I'd try this here, cause i'm not sure where else to go.
I was on the internet looking for tires for the fun of it, and came across these "1980 F150 rims", with 235/85R16 tires on it. The rims look mix matched, from older gen trucks.
heres a pic.
Anyone here knows what generation, if any had 16" rims on half tons?
Old 08-10-2012, 09:40 PM
DAV1972 DAV1972 is offline
DAV1972 is starting off with a positive reputation.
My 1970 F100 came with 5x5.5 bolt pattern 16" wheels. The tires were g78-16 tube type. Those tires and wheels were stolen from me when I put my mags on for the first time. They lasted one night in the back of my truck before they "disapeared". Anyways, I wanted to find those type wheels again and finally did. Took me quite a while to find them. I have not mounted tires on them yet. The tire size might have been 7.50x16? Now I don't remember the tire size exactly.
Old 08-10-2012, 10:18 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
5 lug, 5.50" bolt pattern 16" wheels were standard equipment thru 1954, became optional in 1955, were available thru 1979.
The left wheel is an "outie" (1965/79). The center and right wheels appear to be "innies" .. depending on width, 1948/52 F1 or 1953/66 F100, 1966 Bronco.
Outie = So called because the hubcap snaps over tabs located on the outside of the wheels center section.
Innie = So called because the hubcap snaps onto tabs located on the inside of the wheels center section.
Anyone ever heard of 16" rims for F150? IDIDieselJohn 1987 - 1996 F150 & Larger F-Series Trucks 7 08-10-2012 04:28 PM
1980 F150 with 16" rims???? IDIDieselJohn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 08-09-2012 10:18 PM
Rim Width Sanders Brakes, Steering, Suspension, Tires, & Wheels 4 12-26-2009 05:03 PM
tire size on stock rims ol74hb 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-26-2009 08:17 PM
Will these used rims fit my truck? Itch71 1987 - 1996 F150 & Larger F-Series Trucks 7 12-13-2007 06:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
