'86 F150 Resto-Mod or The (mis)Adventures of El Guapo
#196
Well, it needs a bunch of TLC before going back to paint. TC was telling me that he knew some good shops if he couldn't work it in when it is finally, really ready. So I am going to try to do the most of it myself, and then let them finish it up, again. Painting it myself, I feel, would be a quick trip to disasterland.
#197
Fortunately, not to much. It could have been much worse. I lost a lot of time, and spent some money dragging it to Ricks, and then getting it taken over to Bay One. I didn't lose anything from Bay One, except some time, but I made a friend, so I don't regret it. Now, I have to finish my plan of attack, order parts, and start working on it again. And figure out where to store my 73 Mach 1 rustmobile.
#198
My problem is that I don't know what is right and what isn't. My first guy put the new cab corners on and they looked ok to me. The new guy cut one off and redid it as it didn't pass muster. And, he spent a lot of time getting the shut lines on the doors right with the cab. It took a lot of tweaking to satisfy him. And, he redid the roof of the cab that the other guy had done. So, I'm not a good judge of "correctness" and would rather pay someone who is.
Besides, you've done major things to the truck given the engine and suspension. Like I've done on my engine and am doing on the trim. I just ordered NOS F150 and Ranger badges which cost $78. And I bought NOS wheel well trim for $200. And a NOS chrome grille for $125. And I'm working on NOS side trim, with 3 of the 8 pieces coming in at $145 w/o shipping, and shipping is going to be a killer given the lengths involved. So, by the time I get them and add the headlight doors and trim above and below the grille I'll have $1000 in the trim alone.
So, I really do want the body and paint work to be done well and I'm far enough in I'm not going to start cutting corners now. You?
#199
#201
Thanks. Getting back to work on it now. Trying to get all the parts organized, and I've got some more parts on order. Just got some plastic sheet to modify the taillights so I can fit flat LED's in place of the incandescant bulbs. that will give me more room for my hinge mechanism and fuel cap. Don't worry, I'll take pictures and post them up on my progress.
#205
Well, it's been a while, but I am finally getting back to work on El Guapo. I decided to start with the tail light hinge to conceal the fuel filler. My wife gave me the idea to use a piano hinge and that got me thinking. I found a 3' section of piano hinge at Lowe's that was nickel-plated steel and had 1/8" diameter barrels. Welding them together flat to flat and alternating up and down orientaiton would allow them to fold into a zig-zag that will allow extension of the taillight and it's moving out of the way of the fuel filler.
Mocked up with cardboard.
A different view of the cardboard mockup.
The piano hinges taped together and mocked up.
A different view of the taillight hinge.
And a partially closed view of the taillight hinge.
After butting the hinges together, I used scotch tape to hold them together. Everthing seems to fit so now I can weld the hinges together, but my welding table is still in storage. I'm hoping to get it home today. Then I can get my welder set up and tack the hinges together and make it permanent.
I'm going to spot weld it to the truck and epoxy it to the taillight. I think I should make one pin removable so that the tail light is removable, but if someone has another idea, I'd be glad to hear it.
Anyway, that's what I've got going on right now.
#206
I noticed on the bedsides that there is a small ridge that I had not noticed before.
This truck had a bedliner in it for most of it's 28 years, and it covered that area. Are they supposed to be that way? The top of my '94 F150 bedsides is flat, without that "style line". I can't help but think it's normal since they are the same on both sides and very regular. If someone can take a look at your truck, I'd appreciate you letting me know if this is correct, or if somewhere along the way, the top of El Guapo's bedsides got messed up.
#208
#209
#210
