78 f250 printed circuit board
If you want genuine NOS Ford
Circuit assy, instrument cluster printed
D6TZ-10K843-B
Fits: 76-up E100-350, F100-350
used on instrument cluster w/ ammeter and oil pressure gauges
marked D6TF-10C956-BA
Tison Motor Co., Estill, SC has 1 (803) 625-2551
Green Sales, Cincinnati, OH has 6 (800) 543-4959
Haven Ford, Haven KS has 1 (620) 465-2252
D6TZ-10K843-B
on
If you get the cluster used, get one out of a 1981 or later Econoline with the same D6TF-10C956-BA marking on the printed circut.
The redesigned plastic materials of the cluster backs of the 1981 and newer econolines do not suffer from cluster rot syndrome. Those cluster backs are marked with a E1UF-10848-AA prefix on the plastic for guages. Those "E1" cluster backs are interchangeable all the way back to 1975/6, if you swap printed circuts to match the original.
on
the two I purchased online did not match the light socket pattern for my cluster. the cluster i recently found does not have a rotten back. and i'm not sure my ammeter works but at least it sits in the middle an pulls to the right as I accelerate. the other gauges never move at all
With Gauges:
I want to check to see if it's for a 1976-1979, or for a 1973-1974, or 1975.
The printed circut boards won't interchange before 1976, and the cluster backs wont interchange before 1975.
Warning lamps are not interchangeable with gauges, and have their own year differences as well.
Google Image Result for http://broncograveyard.com/images/catalog/7679PRNTDCRCTBRDLGT.JPG
this is the one I got in the mail
76-79 Printed Circuit Board, Gauge
and this is what mine looks like
Please, when asking questions, list ALL the pertinent info, we are not mind readers.
Your "About Me" profile says 1978 F150. If this is correct...
D6TZ-10K843-B .. Printed Circuit Board-Use with Oil/Amp GAUGES / Marked: D6TF-10C956-BA / Obsolete ~ 4 available NOS
1976/79 F100/350; 1976/91 Econoline; 1978/79 Bronco.
D6TZ-10K843-C .. Printed Circuit Board-Use with Oil/Amp WARNING LAMPS / Marked: D6TF-10C956-CA / Obsolete ~ 0 available NOS
1976/78 F100/350 & Econoline; 1978 Bronco.
Maggie T
01-29-2014 09:06 AM
Hawkmcgee
08-24-2013 09:12 AM
HillbillyHellcat
03-06-2004 07:26 PM
