2003 F350 superduty front leveling question - Ford Truck Enthusiasts Forums
Old 08-09-2012, 01:09 PM
waynejaynes's Avatar
waynejaynes waynejaynes is offline
waynejaynes is starting off with a positive reputation.
My 2003 f350 superduty has leaf springs in front with a tracking bar, Is it possible to remove the tracking bar since the leaf springs keep front axle in place? can I just add extra leafs to lavel it up to match rear? Thanks Wayne
Old 08-13-2012, 06:00 AM
4x41977 4x41977 is offline
4x41977 is starting off with a positive reputation.
Yes you can add leaves and it will make it ride rougher. No you can not remove your track bar.
Old 09-05-2012, 08:55 AM
greasolution greasolution is offline
greasolution is starting off with a positive reputation.
My 02 F350 is way lower in the front also. Instead of adding springs can a block be added to raise it?
Old 09-07-2012, 06:20 PM
Off Road Design makes a no rate leaf spring, that looks just like a block. I put one in my front end after I removed two leaf springs to get a smoother ride. I think it was an inch or so. It goes under the leaf springs and the center bolt goes through it.
OEM front leaf spring bracket ryan2100 1999 to 2016 Super Duty 4 04-01-2010 01:02 PM
Lower 4WD 2003 F-350 with leaf springs Eastfrisian 1999 to 2016 Super Duty 6 02-04-2009 01:08 PM
Front Leveling kit - Shackle vs. leaf spring add on bjm58 1999 to 2016 Super Duty 7 11-26-2007 07:51 AM
Front Leaf Springs 99 & 04 cowboyty 1999 to 2016 Super Duty 1 10-10-2006 11:08 AM
track bar? 92f150I6 1999 to 2016 Super Duty 1 07-25-2004 09:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
