F-150 1990 5.0 xlt lariat 4WD front brake disc change??? Need help
Good day, could someone can help me a bit. How do change my ford 5.0 xlt lariat 4wd front brake disc? Do I need special tool for removing nutīs what are holding wheel lock bearings? If I tight them later does they have certain tightening torque? Doese someone have good drawing for front wheel assembly?
Really need help.
Thank you!
Mike
Really need help.
Thank you!
Mike
on
You may need a service manual to do this. There is a special socket needed to remove the wheel bearing retainer nuts.. after you completely remove the hub mechanism, and then the studs need to be pressed out and the hub and rotor have to seperated which can be a bear if they have been on there long.
Ford SD
03-31-2015 02:14 PM
grockin2004
03-29-2010 12:26 AM
