1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
PWM vs. NON PWM
Old 08-09-2012, 11:03 AM
ShoTym's Avatar
ShoTym
ShoTym is offline
PWM vs. NON PWM
I have a 2003 Ford F250 5.4L with a 4R100 transmission.
Is that automatically PWM? I'm gonna be attempting to replace the Solenoid pack.
Also other than buying a new pack is there anything else I should consider replacing while I'm in there? I've ready about wiring harnesses but that was for earlier model transmissions where you could just replace the TCC Solenoid.
Thanks in advance for any help. It's much appreciated.
Old 08-09-2012, 11:11 AM
ShoTym's Avatar
ShoTym
ShoTym is offline
Also if I'm driving the truck with a P1744 error code am I risking doing irreparable damage to the Transmission? I'm not towing anything right now.
Old 08-09-2012, 11:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
It is a PWM solenoid.
Have you done any diagnostics or are you replacing the solenoid because of this code?
Driving with that code won't do any harm to the trans unless you overheat it. That isn't likely unless the truck is loaded to the maximum.
Old 08-09-2012, 11:43 AM
ShoTym's Avatar
ShoTym
ShoTym is offline
I was gonna replace based on that code. Is that not a good idea?
I read that it could simply be the wiring. I just am leery about taking it to a Tranny shop and having them come back with a rag full of dirty oil telling me I need a new Transmission.
Old 08-09-2012, 12:20 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
On other Fords, a P1744 usually meant the TC clutches were slipping and they were usually toast, requiring the converter to be replaced along with whatever originally failed.
Mark can probably tell us if the behavior is similar on the 4R100.
Old 08-09-2012, 01:10 PM
Mark Kovalsky
The code means the torque converter is not locking when the PCM is commanding it to lock.
That could be a failed solenoid, a failed torque converter, a stuck valve in the valve body, or a failed seal in the torque converter circuit. If it were a wiring problem there would also be a code for an electrical problem with the circuit.
If you were to get a wiring diagram of the connector on the trans you could put +12 across the TCC solenoid and listen for a loud click when you apply or remove the voltage. While that is not a 100% guarantee that the solenoid is good, it is pretty reliable.
Old 08-09-2012, 01:18 PM
ShoTym's Avatar
ShoTym
ShoTym is offline
well dadgummit. Looks like I'm going to have to get references to a Tranny shop and have them look at it. I was hoping I could save the headache and money and simply change out that solenoid pack. Oh well.
Old 08-09-2012, 01:46 PM
ShoTym's Avatar
ShoTym
ShoTym is offline
would it be more cost effective to purchase a shift kit and solenoid pack first then if that doesn't work take it to a shop? I'm not ready to replace a torque converter, but I feel like I could install a valve body shift kit and solenoid pack.
Old 08-09-2012, 06:12 PM
redford's Avatar
redford
redford is online now
Received 1,564 Likes on 912 Posts
It depends on a lot of factors, like how much do the parts cost, what is the labor rate at the shop. While we can't answer the question specifically, I can say categorically that it is NEVER cost effective to replace parts that work. If you spend $35 to find out a solenoid pack you replaced did not need replacing, you wasted $35.
Old 08-09-2012, 06:31 PM
Mark Kovalsky
You could do that. The shift kit won't help this, the solenoid might. You might be spending a bunch of money to change a good part. Your call.
Old 08-09-2012, 07:23 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Great idea!
Mark, do you know if the pin out (wiring diagram) for the 4R100 is the same no matter which engine is installed? If so, then here is the info from my 7.3 manual...
(hope this helps...)
Old 08-09-2012, 08:16 PM
Mark Kovalsky
Yes, it doesn't matter which engine, they are all the same.
Josh Baker
09-18-2017 08:20 PM
Greek 350
03-15-2012 08:02 PM
sjl74
08-02-2005 09:11 PM
Quick Reply: PWM vs. NON PWM
