I have a 2001 SuperCrew 4x4 with approximately 53,000 kms on it. I would say that 90% of the Kms come from highway driving. Now, I am getting a vibration in the steering wheel. Contacted my dealer who says it sounds like the tires are shot. Should they be?? They are GoodYear.
See what "Goodyear" has to say. Most tires should last around 75-80K with normal driving. Although I know some people who can go through a set in a lot less time and distance.
I think you've just discovered your problem. Take it back to the outfit that did your ball joints. Sounds like something's loose.....tie rod end, or a wheel, perhaps?
Rick
Edit: As Powerstroker mentioned, if the tires were rotated at the same time, perhaps one of the rears, now on the front, needs balancing.
