Trans, transfer case and diff after wreck ?'s - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-09-2012, 12:15 AM
04Terminator 04Terminator is offline
04Terminator is starting off with a positive reputation.
Well my truck was rear ended in park and moved about thirty feet, it was in park without the p-brake on. 01 350 cclb srw 7.3 auto lariat. Estimate on repairs is 8600$. My ?'s are could thes three items be damaged from the wreck? It started fine and I had to reverse it off of a retaining wall that the rf tire caught that broke the internals of the steering gear box. I know that there is a transmission engineer on here maybe he can chime in on this. I think I can post pictures at my 25th post got pics of his car too. Will post pics soon. Thanks adding some pics of the carnige. The fist pic of the steps and hand rail is where my truck was parked and the second is where it came to rest.
Old 08-09-2012, 03:25 AM
A few more.
Old 08-09-2012, 09:21 AM
bcaughhorn's Avatar
bcaughhorn bcaughhorn is offline
bcaughhorn is gaining momentum as a positive member of FTE.
they can be damaged. i just talked to a guy in tx he got rearended and told me the ins put a new motor in his truck and they called him and wanted him to come down to look at the transfer case so he was thinking its broke too
Old 08-09-2012, 10:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
They could be fine or they could be destroyed. It takes an onsite inspection to know.
Old 08-09-2012, 08:50 PM
BadDogKuzz's Avatar
BadDogKuzz BadDogKuzz is offline
BadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud of
Well like Mark said an on site inspection is the only real way to tell. But can you see any damage under the truck? Is the trans mount still centered? Any damage to trans or transfer case ? What does the drive shaft look like?
But by looking at the photos it does look like there is frame damage. What were they planning on doing with the frame? Make sure it goes to a body shop that has a frame machine and a measuring system that can give you a print out of before and after repairs. Machines like Shark, Chief's Velocity or CarOtronic. Trust me when I say you don't want some hillbilly pulling your frame and using a tape measure to see if it is in specs.
Old 08-10-2012, 12:41 AM
Crap this really bothers me, the bs is supposed to be very good. They did a great job on my cobra but it was minor damage. I just hate this cause I had waited a long time for this truck and it was a nice one. I'll do a visual inspection tomorrow see if I can get po'd any further. Thanks
Old 08-10-2012, 02:03 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
get more "quotes". i could'nt imagine with it being in park, that it didnt screw something up. heck, i drove a mile to the first exit on a flat (p/s rear), and from that, the diff was all screwed up. Felt as though it was binding up, once i put the same size spare on.....anyway, good luck man, hope it works out for ya
Old 08-10-2012, 02:27 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Well with the parking brake set it took the shock load off the parking pawl and your truck just skid on the tires once it broke traction so no real worries i think.
Old 08-10-2012, 07:50 AM
Quote:
That would be true if he had the parking brake on. But he didn't.
Quote:
If the parking pawl in the transmission were damaged you'd know it right away. The truck would be able to roll when the shifter was in park. If it holds in park then the park system still works.
Old 08-10-2012, 04:13 PM
Thanks for the info anything else I should be looking at?
Old 08-10-2012, 04:59 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
I misread it too. I thought it was set as well until i read mark's post.
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 12:59 PM
picture test 04Terminator Testing..... 0 08-09-2012 02:54 AM
1986 F150 money pit / trail rig / SAS 4 link '88_F-150 Offroad & 4x4 27 08-27-2011 03:48 PM
post your pics! 9.ford.5 Alberta Chapter 3 10-17-2009 10:18 PM
White residue over degas bottle? KING 6.0L Power Stroke Diesel 87 08-26-2008 07:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
