I think my CPS is going bad truck runs fine but occasionally I get a split second skip or hiccup , dors this seem like a CPS issue?
I have the warrentee CPS , to replace the CPS is it as simple as remove bolt pull CPS re-install and plug in , or is there more to it than that I might try before work I have a 1/2 hour slack time, Ya'll think I can get it done in 1/2 hour?
Thanks , I will try in the morning I have part F7TZ=12K073-B its gray ... Crossed fingers it sounds too easy after reading all those bad CPS threads over the years.......
Here's a picture of the different varieties of CPS units.
That's, from left to right, C, B, and A. Unless I am mistaken, C (Dark grey with the indigo-looking o-ring) is the latest and greatest. That would be what I recommend that you use.
Done , took about 20 minutes its a tight spot with a snow plow frame in the way but still twenty minutes and the truck ran all day and never a hiccup ,,,,,,,,, thanks for ya'lls help
