Shocks For Leveling Kit on 1999 F250 SD 2WD - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-08-2012, 06:18 PM
F250Bruiser F250Bruiser is offline
F250Bruiser is starting off with a positive reputation.
I am currently purchasing the components for a leveling kit on my 1999 F250 SD 2WD. I got the 2" aluminum spacers and now I am working on the shocks for it. I will be using a shock conversion that will use the eye ring bushing rather than the OE stud mount.
My question is...What length shocks should I got with? 0"-2" or 2"-4" of lift? And any recommendations on the brand and style of shock would be greatly appreciated! Thanks in advance!
Old 08-08-2012, 07:48 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
What eye ring bushing conversion kit are you using? Depending on how and where it mounts will determine what length shock you need.
Plus, I would be interested in seeing the option. I ended up welding an extension onto my stud to get a longer shock for my leveling kit. The shocks I found for a 2" lift had a ride quality that was much less than desirable.
Old 08-08-2012, 08:05 PM
These are the ones that I was considering. It extends the mounting location about 1 1/8" away from OE location.
Old 08-08-2012, 08:16 PM
F350-6's Avatar
Quote:
That would bw 1 1/8" away from the center of the eye. Add another 1/2" - 3/4" or so from the center of the eye to the top of the shock and you'd probably be best off finding a shock that has what is considered the standard length since your new mount will take up almost as much room as your coil spacer will.
The problem is going to be finding a shock with those dimensions, that has a round eye top and bottom, and offers the same amount of travel. I hope you find something. I didn't have any luck when I searched, which is why I ended up welding the extensions on my shock studs and used some spacers to make it all fit right.
Old 08-08-2012, 08:33 PM
That's what I was thinking. I figured that should just go with the 0"-2" length because with the addition of the shock conversion, it would be as the the shock was still at stock length. Just wanted to make I had the right idea. I was thinking that a Rancho RS9000XL might work for my application....
1999-2004 Ford F250 Superduty 4wd Rancho Leveling System Excl. Chassis Cab or AWD (Lifted 2 1/2" Front, NA Rear) - Rancho RS9000XL Shock (Front)
1999-2004 Ford F250 Superduty 4wd Rancho Leveling System Excl. Chassis Cab or AWD (Lifted 2 1/2" Front, NA Rear) - Rancho RS9000XL Shock (Front) - RS999264 | $105.99
Old 08-09-2012, 07:06 PM
F350-6's Avatar
No, that won't work. You can't use a 4wd shock on a 2wd truck. The 4wd mount bolts to the frame and extends above the frame so they're not even close to being the same size.
The 2wd shock has a compressed length around 10.3" and a fully extended length around 15.3". That gives you about 5" of travel.
The 4wd shock for the same year model, or more specifically, your Rancho Shock that you mention has limits of
Rancho RS999264 shock. Compressed length: 15.625" Extended length: 24.375"
Travel: 8.750"
So that means by the time you install the eye mount, you cannot even compress the 4wd shock enough to install it, much less have any travel for absorbing any shock.
Old 08-09-2012, 07:44 PM
Excellent! Thank you for the tutorial! I will hone in my search and see what I can come with.
Old 08-09-2012, 08:58 PM
F350-6's Avatar
If you want to look into shocks, look at this site Rancho, Bilstein, Pro Comp and Fabtech Shocks
They are nice enough to give you dimensions on different shocks if you think you find the correct model number. You can also look around here since Rancho is a sponsor here. They have someone who has been quite helpful in the past trying to help find shocks for odd applications.
He helped me find a longer shock that would possibly work with the standard mounting configuration, but the shock proved to be too long for the rough roads I travel. Bottoming the shocks out proved to be the end of them.
Here's some reading for you on my latest attempt in finding the perfect shock. http://www.ford-trucks.com/forums/11...ck-travel.html
Many others have had no issues at all just running the stock 2wd front shock. As usual, I wasn't one of the lucky ones.
Old 08-09-2012, 11:54 PM
Thanks for the read! After reading and researching, I came across some Daystar Scorpion shocks
These speficially for F250 2WD with a 2" lift. Anyone run these Scorpion shocks before? Thanks for all of the help!
Old 08-11-2012, 07:36 AM
F350-6's Avatar
Yes, I tried those and one other brand I got from 4 wheel parts. They suck. The ride quality is pathetic with those.
2003 2wd with leveling kit shock question billpinsc 1999 to 2016 Super Duty 1 12-28-2016 10:18 PM
How much shock travel? F350-6 1999 - 2003 7.3L Power Stroke Diesel 60 07-25-2014 02:00 PM
Front Shocks for 2WD leveling kit? Gangly 1999 to 2016 Super Duty 5 03-09-2014 01:10 PM
Bilsteins and 2WD Front Leveling kit... ???s F250_ 1999 - 2003 7.3L Power Stroke Diesel 18 11-04-2013 04:04 PM
Help with Bilstein shock selection rcklnhunter 6.7L Power Stroke Diesel 35 05-20-2011 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
