Betty turns oil burner
#1306
#1307
#1308
That's funny! Just how I feel about guys who buy cherried out vehicles or show cars/trucks then act like it was their doing.
No problem, I'm not done yet for sure. I'll definitely have some more updates in the near future. I hope to have the exhaust done, fuel sump in, the seats in and a few other small things buttoned up withing the next month or so.
#1309
#1310
Thanks, seems my thread has turned into somewhat of an animal.
Sounds mean for sure. I'm going to tone her down a bit here soon. I have an aero turbine 4040xl sitting on the work bench ready to rock as soon as I get my tubing. Should sound good but be mellow on the low end.
Should sound close to this guys truck, with more turbo sound and a slightly different idle due to my cam.
#1312
A little update today.
Had a small snafu the other day. I was re routing my boost line and bumped my fan. When I did that I noticed the fan pulley moved as well. Upon further investigation my dampner moved as well. So that was my what the hell moment. I crawled under my truck and found all four balancer bolts out around a half inch and a the edge of my belt shredded a bit. I am unsure if I forgot to torque those bolts or what. I know I did not loctite them. Fortunately all it really hurt was the belt. I decided as usual to go above and beyond for my piece of mind fixing the issue. I didn't take any pictures of this but I made a small jig to hold the bolts and drilled the heads for safety wire. I put them back in with red loctite, torqued them down and safety wired them.
At least now if the bolts do loosen they won't rotate out enough to come out and lose the balancer.
Next up I finally tackled the puke tank. I was tired of looking at my converted bicycle bottle.
I took my passenger radiator mount and added a bracket.
Painted her up, and installed.
I'm glad nothing else needs to go under the hood. Not a whole lot of room under there now.
#1314
#1317
#1318
No, I have'nt forgotten about my fire truck horn. I may start on that next week. I need hose, fitings, and a solinoid.
Yep, you're correct. I'm still on the fence whether I want to make some or use two factory hold downs.
#1319
Factory battery hold downs aren't that great, usually in order to get the side bars that have minimum capture to not pop out you have to over tighten them to the point the top bar bends.
Wouldn't be a problem if batteries were actually the same size that they were when these trucks were new but most batteries have gotten smaller.
That and being the selfish guy I am, I want to see what you'll come up with. haha
#1320
