Betty turns oil burner
#1232
#1235
#1236
#1239
Thank you gentlemen!!! I'm super thrilled everything went so good. I still have things to button up for sure before I driver her. I still need to:
Check her over real good for leaks.
Change the tail shaft bushing and seal
Install the intermediate shaft
Instal seats
Wrap up the battery cables.
Mount a puke tank
Get some 7/8" oil line for a road draft tube
Running bleed the power steering
Build my exhaust
Tie up some lines in the frame
Get and install a speedo sender
And the most hard to swallow, change the oil. Damn I hate that part of cam break in. 3 gallons of 15/40 diesel oil and a wix filter in the trash. There goes $70.00.
I also need to mount my horn and the air tank. I'm thinking the horn is going on the passenger frame rail real close to the bed side tool box. The air tank opposite. I was going to mount it under the hood but there is just too much under there already. And I think the last item will be to hook up the grid heaters.
I think that's it. I hopefully can get this all taken care of by the end of the month. Whew!!!
Instal seats
Mount a puke tank
Build my exhaust
#1241
#1243
#1244
Congrats on getting it running! I've read through your build but never really got a chance to comment on it, but you do awesome work and I definitely have some inspiration for future plans for my truck. That first start is awesome, and you didn't even need any ether like I did! I feel your pain with the expensive oil change pretty soon, it sucks but it's just part of owning a diesel.
Great work man, there's a lot to be proud of there and I'm excited to see when you get her on the road.
