Edge Evolution - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Edge Evolution
Old 08-08-2012, 10:01 AM
ramrod7373 ramrod7373 is offline
ramrod7373 is starting off with a positive reputation.
Edge Evolution
I had a old Superchip in the truck when I bought it. It was losing connection and making my truck die at wierd times. Took it out and no problems for about a year and bam my computer went out. Put a re-built computer in there and all is fine. Just wanting a little more power up hills towing my travel trailer. Called Superchips and they said I could trade it in on a Edge product.
I choose the Evolution because I didn't have to do anything else to my truck. Plus I got it for $100 and they retail for over $350. Only use it in tow mode. Sometimes it will make my speedo jump around. I never did this when it was stock. It runs fine otherwise. Anybody else have a problem like this w/ an Edge tuner?
My truck has 6637 and cat delete and 4" exhaust. Stock downpipe and that's it for upgrades.
Thnx
Old 08-08-2012, 10:30 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Shoulda stuck with the superchip.
The speedo jumping around shouldn't have anything to do with your PCM though. But then, the edge is a programmer, not a tuner. So, if it changes some weird thing I dont' know about then. *Shrugs*
The VSS and that's in the rear axle and that controls the Speedo.
Check the connection on it and make sure its tight and clean.
Old 08-08-2012, 11:42 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Lightbulb
Thnx
Read this link:
http://www.ford-trucks.com/forums/11...rogrammer.html
Old 08-09-2012, 09:19 AM
The superchip was the old style that plugged into the side of the computer. I wasn't going to plug it back in and have the same problem again. Superchip doesnt make a tuner/programmer for my truck so I went w/ the one I could afford w/ out doing alot of expensive upgardes to my truck. I didn't notice a difference when I pulled the old chip out anyway. I DO notice a big difference w/ my truck in tow mode though. So I will prob roll with it this way and see what happens. I will send Edge an e-mail and see what they say.
Thnx for the input
Old 08-09-2012, 09:33 AM
Talyn's Avatar
Nothing wrong with edge, just most of us here are against any style of programmer because they reflash the PCM instead of bypassing the pcm, so if it has a failed flash, you have a toast PCM and gotta send it to somebody who can flash PCMs.
Thats all. =)
Hot transmission after towing in my 02 mikeb2 1999 - 2003 7.3L Power Stroke Diesel 9 07-22-2012 12:06 AM
ECM issues? or programmer issues? Oversize 1994.5 - 1997 7.3L Power Stroke Diesel 1 02-24-2009 08:49 PM
Edge Evolution possibly draining battery? GBSIGNS1998 2004 - 2008 F150 41 07-04-2008 10:55 AM
Edge Products Question? burbur23 1999 - 2003 7.3L Power Stroke Diesel 2 11-17-2005 12:14 PM
Edge Evolution W/ Edge Attitude HOTFOOT 1999 - 2003 7.3L Power Stroke Diesel 6 11-08-2004 07:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
