Trailer Mirror Upgrade
Old 08-19-2011, 04:48 AM
FROG147's Avatar
FROG147
FROG147 is offline
I currently have a 2004 F250 with standard power (non heated or turn signal) and am looking to upgrade to a telescoping trailer mirrors with heat and turn signal. I have received mixed information on wether this is doable due to wiring. One would think that the base wiring harness would be standard, then from the connection to the mirror would be were the options vary (pin outs from the wiring harness). Any insight into this is appreciated.
Old 08-20-2011, 09:54 AM
ReAX's Avatar
ReAX
ReAX is offline
The towing/heat/turn mirrors will bolt up. Wether you have the wiring in place for the turn signals is questionable, but it's easy enough to do. Muth Mirrors has a pretty good write up with pictures on how and where to tap for turn signals should you need them.
Old 07-02-2012, 04:41 PM
dopage's Avatar
dopage
dopage is offline
Did you have success with upgrading to new mirrors, was wiring harness in place?
Old 07-27-2012, 03:06 PM
Eskay305's Avatar
Eskay305
Eskay305 is offline
I have the same model and year and have the small mirrors that are just power for moving them. It appears the power only has a small round plug where as the others have a flat grey plug. I want to upgrade to power with the blinkers in them. I have considered splicing the wires together and running a new wire for each blinker if the wire is not already there.
Anyone have an opinion on doing it this way?
Old 07-29-2012, 08:04 AM
ReAX's Avatar
ReAX
ReAX is offline
mrwhite_350
1999 to 2016 Super Duty
25
03-07-2015 08:07 PM
Waff78
2004 - 2008 F150
02-06-2015 09:55 AM
FROG147
08-19-2011 05:30 AM
fdrf150
1997 - 2003 F150
10-16-2007 09:50 AM
stvsr1
10-14-2005 06:24 PM
Quick Reply: Trailer Mirror Upgrade
