Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 08-07-2012, 05:52 PM
chuckg's03 chuckg's03 is offline
2003 Ford F-150
chuckg's03 is starting off with a positive reputation.
GF Chips
Does anyone have experience with these performance chips? Do they work well? Is there a better brand for a 5.4L V-8?
Thanks
  #2 (permalink)
Old 08-07-2012, 06:05 PM
projectSHO89 projectSHO89 is offline
Garage is empty, add now
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Never heard of them....
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #3 (permalink)
Old 08-07-2012, 06:16 PM
2003 Ford F-150
Sorry, G Force chips.
www.gfchips.com
  #4 (permalink)
Old 08-07-2012, 10:15 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Have you read where the device is connected?
It is to the Intake Air Temp plug (IAT).
The only thing this does is have an effect on timing and possibly fuel by placing different fixed resistances in place of the sensor.
This does not reprogram the ECU in any way.
It's only an input resistance signal same as the CHT and some other sensors..
The chip likely is a resistance network who's values you might be able to select with a switch.
I won't say it will not do anything but this is what to expect it might do.
Good luck.
  #5 (permalink)
Old 08-08-2012, 04:45 AM
Archion's Avatar
Archion Archion is offline
Trained Parts Monkey
1996 Fleetwood Wilderness
My Garage
Archion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud of
Archion.Uberpimp PartsGuyMatt mvose OVC Archion
True "chips" are only used on pre-OBDII vehicles, Fords that had the service port on the ECM, GMs actually required changing of the eprom back in the day. OBDII vehicles need to be flashed with a tuner, anything else is bullsh**. The same goes for intake spacers, tornados, luke warm air intakes, hot air intakes(true cai pulls air from outside) and anything else you can buy from the chromeformance section at Autozone/EBay.
Except maybe Stickerzz, Stickerzz add lots of powa, just ask the ebayers...
__________________
Matt - Ninja Edit Master
02 Excursion XLT V10 4WD - 12 Escape L4 XLT AWD - 99 Mustang 3.8L 'Vert - 96 Wilderness 22LW TT
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
Carlisle - 2012 Mid-Atlantic Meet - Pic Thread >>CLICK ME<<
  #6 (permalink)
Old 08-08-2012, 08:32 AM
2003 Ford F-150
Thanks for the info. I'm glad I asked.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
