Anyone else did the "Cold A/C" mod?
Hmm, sounds interesting, but isn't there a 'mixing valve' type thing on or near the heater plenum that basically does this? Not sure, but I know my 2 older Mustangs (both 1967) and my Cougar all have this type of set up from the factory. If our trucks don't have this, though it sounds like a pretty decent idea...
Roger
Roger
I did mine over a year ago and it works just fine !!! I got the idea from my Peterbilt ... it came with shut off's at the block !!! On my F250 I made an "H" shaped by-pass with 3 "screw type" valves so coolant would recirculate when by-passing the heater core... yes it is a bit of over-kill At that time I replaced ALL heater hoses with blue silicone hose.. (truck drivers favorite) ... should last for a L O N G time Dave
Thanks Mongo!
I don't think the coolant not circulating to the heater core in hot weather is going to have any negative effects, will it?
At any rate, I'm 99% tempted to go on, and pick up a valve and toss it on...
Also...
Did anyone else's A/C-Heater Core box have the silver insulation?
Mine has a few shreds, and I'm wanting to re-cover it....To help eliminate heatsoak....From the engine bay...
My I6 LOVES to produce heat...Seriously, the fenders are hotter than all get out after a hour long run....
Also...
I redid my foil after putting in headers a few weeks back.
looking for a link to the stuff its the 2k degree reflectance self-adhering type (mat not tape) . I only took the time to clean where it adhered. dont make for pretty pics
Edit: cant find a link but its off the shelf at CAP. 20 ish bucks 1 package does it all with scissors thought and time.
I would re-think the 165* T-stat ... your computer will think your truck hasn't heated up yet and will over feed gas like during a cold start and you MPG WILL DROP !!! Yes it's true check it out !!!! Dave
Side Winder
[QUOTE=SideWinder4.9l;12132740]Thanks Mongo!
I've done it on all my semi's for many years .... no problems Dave
