speed sensor location - Ford Truck Enthusiasts Forums
Old 09-20-2002, 09:32 AM
flgal flgal is offline
flgal is starting off with a positive reputation.
Post speed sensor location
I have a 96 Ford F150 4 wheel drive pick up. I was told that the speed sensor was bad so I purchased one to replace. I have no idea where it is or how difficult it will be to replace. Can anyone help?
Thanks,
flgal
Old 09-20-2002, 09:39 AM
wbw189 wbw189 is offline
wbw189 is starting off with a positive reputation.
No problem. The speed sensor/ABS sensor is located in the rear differential just above the drive shaft. It only takes one connector to pull off and one bolt to remove. The bolt on my 94 is a 13mm. It is pretty darn simple. Good Luck and keep us posted.
Ben
Old 09-20-2002, 12:35 PM
frey69 frey69 is offline
frey69 is starting off with a positive reputation.
speedometer is not working Paul Bostic 2004 - 2008 F150 0 02-07-2017 07:54 PM
2004 Sport trac V6 P0715: Input/Turbine Speed Sensor Circuit radmacks Explorer, Sport Trac, Mountaineer & Aviator 1 09-12-2016 10:32 PM
Fan speed sensor question? gairforce1 6.0L Power Stroke Diesel 5 09-22-2011 09:37 PM
Where is my speed sensor? Code 6 RABS ErrorS 1978 - 1996 Big Bronco 2 05-13-2011 08:51 PM
Four Wheel Drive Sensors ptm526 Explorer, Sport Trac, Mountaineer & Aviator 3 03-03-2003 09:38 PM
Tags
1987, 1996, 1999, 42, 96, diagram, f150, ford, located, location, senor, sensor, sensors, speed, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
