Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 08-07-2012, 10:03 AM
iggy.ho iggy.ho is offline
Garage is empty, add now
iggy.ho is starting off with a positive reputation.
gear box id
Hi, i'm new to this site so please bear with me! i'm installing a 5.0 engine in my 1959 f-100 and wanted to use a manual trans. I bought a good used trans, supposed to be 3-speed with overdrive, not a granny gear 1st. A mid 80s truck trans?? Aluminum case, 4-speed top shifter. # on tag-rts bvh8 e6trma0992 what trans do i have?? Thanks
  #2 (permalink)
Old 08-07-2012, 01:42 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Sounds like the top shift version of the 4 speed OD. Other versions are the SROD, where the shifter is back on the left on a turret with a tube connecting it to the main box. And there is an iron cased side shifted version as well. These are patterned after the old Ford "Top loader" performance four speed from the '60s/'70s. They are also called "T170"s.
Aluminum cased versions are the weak sisters of the group. Don't side step the clutch or bang gears....
Domestic Truck Transmission Identification Guide - Rockland Standard Gear, Inc.
Ratios here.
Toploader 4 Speed Transmissions
The site where I found pics is no longer available, but there is a pic of the guts here on the iron cased job:
Toploader Imposters
  #3 (permalink)
Old 08-07-2012, 07:44 PM
trans info
Thanks for the info, trans should be good for my use. it's my daily beater/ parts chaser.
  #4 (permalink)
Old 08-13-2012, 03:58 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
I bought a RTS TS-OD 4-speed overdrive trans, aluminum case, 4-speed top shifter. RTS E6TR-MA
What trans do I have?
E6TR-MA = RTS-BV TS-OD (Top Shift 4 Speed Overdrive): 1986/89 F150 302 2WD.
RTS TS-OD = 1984/89 E150/F150 & Bronco.
The multi-part gear shift lever is an abomination foisted on mankind by FoMoCo. The trans is a notorious "weak sister."
One speed shift, you can kiss the little darlin' good bye.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 08-13-2012, 08:28 AM
gear box
sounds like i should buy a truckload of these trans and keep them handy. the reason i am using this trans, i like the original look of the floorshift, but with the overdrive. Thanks Iggy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
