New A\C not blowing as cold
Old 08-07-2012, 06:59 AM
jwreels's Avatar
jwreels
jwreels is offline
I have been working on the A\C on my 2000 F350. The original problem was that the A/C would blow cold for about 15 minutes upon startup and then start blowing non-cold air. I started by checking for leaks and checking if it was low on freon. There was a tiny leak and slightly low on freon.
I ended up replacing the compressor, accumlator, condensor, evaporator and new oriface tube. We flushed the hoses, and put 9oz of oil and 42 oz of 134a. Hooking up the gauges we get a low side pressure of 60 and high of 225. Everything is sweating and cold. During the hot Houston day the air temp coming out of the vents to 70.
Other Information :
We used a Robinaire 34988 recovery machine and flushed the hoses with a flush gun.
With the truck idling at 2000 rpms the pressure is 26 and 275 and the air coming out about 60 degrees.
Any ideas ?
Old 08-07-2012, 10:50 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Your refrigerant section is fine. You have a problem in the heater door area of the plenum.
Try clamping off the heater core coolant loop to test.
Old 08-12-2012, 06:50 AM
jwreels's Avatar
jwreels
jwreels is offline
So after clamping off the heater core, the temp coming out of the vents will get down to ~62 degrees. This is during hottest part of the Houston day where outside temp is in the upper 90s.
Is this correct ?
Old 08-12-2012, 08:47 AM
projectSHO89
Depends on the inlet air temperature. Usually, if you can get 25-30 degree drop in air temp across the evaporator, you're doing fairly well.
SoCalAngler
1999 to 2016 Super Duty
08-06-2017 11:11 AM
kr98664
06-25-2017 10:32 PM
bigb56
09-13-2014 08:37 PM
Metalx
1997-2006 Expedition & Navigator
12-08-2008 11:26 AM
zarillus
05-15-2008 02:58 PM
Quick Reply: New A\C not blowing as cold
