New A\C not blowing as cold - Ford Truck Enthusiasts Forums
Old 08-07-2012, 06:59 AM
jwreels jwreels is offline
jwreels is starting off with a positive reputation.
I have been working on the A\C on my 2000 F350. The original problem was that the A/C would blow cold for about 15 minutes upon startup and then start blowing non-cold air. I started by checking for leaks and checking if it was low on freon. There was a tiny leak and slightly low on freon.
I ended up replacing the compressor, accumlator, condensor, evaporator and new oriface tube. We flushed the hoses, and put 9oz of oil and 42 oz of 134a. Hooking up the gauges we get a low side pressure of 60 and high of 225. Everything is sweating and cold. During the hot Houston day the air temp coming out of the vents to 70.
Other Information :
We used a Robinaire 34988 recovery machine and flushed the hoses with a flush gun.
With the truck idling at 2000 rpms the pressure is 26 and 275 and the air coming out about 60 degrees.
Any ideas ?
Old 08-07-2012, 10:50 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Your refrigerant section is fine. You have a problem in the heater door area of the plenum.
Try clamping off the heater core coolant loop to test.
Old 08-12-2012, 06:50 AM
So after clamping off the heater core, the temp coming out of the vents will get down to ~62 degrees. This is during hottest part of the Houston day where outside temp is in the upper 90s.
Is this correct ?
Old 08-12-2012, 08:47 AM
Depends on the inlet air temperature. Usually, if you can get 25-30 degree drop in air temp across the evaporator, you're doing fairly well.
94 R134a AC problem Muffinman Aerostar 7 05-21-2013 07:14 PM
2004 expy a/c no cold air please read gatr2000 Cooling, Heating, Ventilation & A/C 5 07-16-2012 05:32 AM
a/c compressor cutting out, but when on it blows ice cold TR6 1999 to 2016 Super Duty 12 07-25-2009 04:57 PM
94 F150XL - A/C stops blowing above 2K RPM... motopsyko32 1987 - 1996 F150 & Larger F-Series Trucks 16 09-22-2005 06:21 AM
A/C Confusion?? dgalloway Cooling, Heating, Ventilation & A/C 5 08-25-2003 10:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
