1969 429 one piece fuel pump eccentric - Ford Truck Enthusiasts Forums
Old 08-06-2012, 09:19 PM
speedwaypj speedwaypj is offline
speedwaypj is starting off with a positive reputation.
<HR style="BACKGROUND-COLOR: #999999; COLOR: #999999" SIZE=1><!-- / icon and title --><!-- message -->I have a 1969 429 Thunder Jet that I've had since 1971 and built it last year for my Cobra project. I replaced most internals including cam/timing chain/gear. I know for a fact that the one piece fuel pump eccentric did not have a Tab or hole in it - so I used locktite and torqued it down.
I'm in the process of installing the engine into the frame - however now - I'm uncertain of what to do. Do I need to rip the front of the engine off - and either Pin or drill / tap the one piece fuel pump eccentric to the cam gear? I've read else where that some of the first 429's did not have any tab or pins?
Last thing I want is for the pump to stop in the middle of no-where..... unless if it's fine then I'll leave it.
(it probably would take less time to tear it apart and fix it than to walk home from the middle of no-wheres)
Suggestion?
Thanks - PJ
Troubleshooting no fuel after timing set replacement Dimitri13 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 9 11-12-2015 11:43 PM
Fuel Pump Eccentric No Alignment Pin Hole tbakko 1968-2013 Full Size Vans 1 10-05-2012 10:13 AM
Fuel pump eccentric question rokford 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 08-06-2011 01:24 PM
WTB fuel pump eccentric tater_51 WTB - Parts & other 6 09-08-2010 02:07 AM
mechanical fuel pump eccentric on a efi block fishin1976 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 49 09-22-2003 08:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
