Flashing OD light
Flashing OD light
Ok, i hooked up the 5th wheel yesterday, started it up, put it in drive and the od light started flashing on the shifter. I turned it off re-started it, put it in gear and it was fine, until I stopped at a stoplight and went to take off, it started flashing again. so I turned it off and re-started, put in gear and no problems, until the next light.
I thoght it could be a short somewhere so I unhooked the 5th wheel lights and it still does it.
It doesnt do this untill I pull the 5th
I do notice when I put it park that the idol go up and then back to normal
The tranny was built and up graded 2 years ago by a well known tranny mech. that works on alot of these trannys
I called tranny mech. and he said it sounded like a speed sensor
any Ideas
any Ideas
