Sealed ball joints 2001 E150
Old 08-07-2012, 11:55 AM
CheesyRider's Avatar
CheesyRider
CheesyRider is offline
I noticed on my recently purchased 2001 E150 van that there are no grease fittings for the ball joints. Did it come from the factory this way, or were these installed by the previous owner? I suspect the latter as my old 1997 E150 had the fittings.
How long do the sealed ball joints usually last? Would it be best to just wait until they go bad to replace them, or should I just do it along with my next bearing repack?
Thanks!
Old 08-07-2012, 02:46 PM
95e150CW's Avatar
95e150CW
95e150CW is offline
They ship with sealed balljoints. If your 97 had fittings, they were probably replaced. Doing the joints is a bitch, and you usually need a press cup sized specifically for E150s, as most kits wont have that size (but you can redneck it!)
If you DO replace the joints, use Moog. Almost every other brand is junk, including (specifically!) parts store brand parts.
Old 08-07-2012, 04:29 PM
avenge's Avatar
avenge
avenge is offline
I just take the whole part to a machine shop and have them press the old out and the new in. They had a hard time getting mine out with a 3 ton press.
Old 08-07-2012, 04:55 PM
95e150CW's Avatar
95e150CW
95e150CW is offline
I used my impact gun and a balljoint screw press. It was still unpleasant.
Unclegrumpy
07-24-2019 06:08 AM
Keny1
03-18-2014 06:13 AM
rickherrera
09-05-2005 06:56 PM
spnrgy
02-13-2005 05:39 PM
Quick Reply: Sealed ball joints 2001 E150
