can i get prebent brake lines? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-06-2012, 03:00 PM
mike oconnell mike oconnell is offline
mike oconnell is starting off with a positive reputation.
Smile can i get prebent brake lines?
Does anyone know if i can get pre-bent brake lines and fittings for a 2001 ford ranger xlt 3.0 liter 6 cylinder? I have seen them for other model fords a JBG website
Old 08-06-2012, 05:20 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Ford still has those parts available, it might take some searching to find which exact section and fittings you need but check out fordparts.com for pictures and part numbers and prices,
If you're concerned about the price being to high, consider the value of having brakes that work correctly, the value of your truck.
Old 09-02-2012, 09:55 PM
1great40's Avatar
1great40 1great40 is offline
1great40 is starting off with a positive reputation.
Way too high
I checked out fordparts.com for the hydraulic brake tubing for my 2000 Ranger, a list price of 140 bucks for the piece of tube that runs down the frame is just way to much. I really wanted to just buy the lines and put them in but it looks like I'll be "rollin' my own" again. Making lines from scratch is a pain but I can deal with it
Old 09-02-2012, 11:14 PM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
heck its just $20 for a 15' roll of steel brake line, yeah, the line nuts start adding up in price, and unions arent cheap either, but once you learn & get good at double-flareing brake line, you can justify the cost of the double-flare tool kit you'll also need. get the "good stuff" yes, its $80 from sears, but the &30 one from autozone just doesnt hold the line good enough when you go to make the flare, i thought it was me being out of practice until i broke down & got a good tool to use then was makeing perfect double-flares every time. you might even find yourself doing work on the side & the tool can litterly pay for itself.
Can't get this line in. Right front brake line. Salty Dog 1967 - 1972 F-100 & Larger F-Series Trucks 13 01-28-2016 09:36 AM
Where can I get prebent rear brake line? '78f350 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-21-2014 11:38 PM
brake lines jerryst 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 03-21-2012 09:21 AM
Pre-bent transmission lines? mitchell390 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-08-2012 08:12 AM
Where Can I Get a Pre-Bent Brake Line? Dancingchicken Brakes, Steering, Suspension, Tires, & Wheels 9 07-03-2009 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
