Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 08-05-2012, 09:35 PM
newrider3's Avatar
newrider3 newrider3 is offline
1982 Ford F-100
newrider3 is gaining momentum as a positive member of FTE.
IM240 Emissions Test requirements
So I didn't manage to catch a passing emissions test from the roadside vans, and have to go in for an e-test for my upcoming registration. Unfortunately my truck is just on the year cutoff where it has to run the stricter dyno test.
What I'm most concerned about is the visual inspection, as I took most of the stock engine equipment off and ****-canned it long ago.
What will they be looking for on a 1982 F100? Cats, EGR, AIR pump I can think of off the top of my head, what else? The EGR and AIR I can fake back together, and I'll probably go ahead and put cats back on. Will they want to check any part of the EVAP system besides the fuel cap? Charcoal canister need to be in place?
If anyone has had to go through this test can shed some light on their requirements it would be most appreciated.
__________________
1982 F-100 Shortbed 2wd - 300/6: Clifford Intake, 500cfm Edelbrock AVS, EFI manifolds, true duals, COMP 260H, port and polish, - M5R2 trans - 3.25 9"
1997 F-350 Crew Cab Longbed 4x4 - 7.3 PSD 5spd - beat to crap work truck resurrection
  #2 (permalink)
Old 08-06-2012, 03:39 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
not sure yet, I need to get a fuel pump into mine before taking it over, but i would be interested in knowing how it goes.
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #3 (permalink)
Old 08-12-2012, 03:45 PM
Thumper19's Avatar
Thumper19 Thumper19 is offline
Garage is empty, add now
Thumper19 is starting off with a positive reputation.
I believe they now do mostly exhaust readings and air thermactor. Through a cat back on and your evap canister along with your smog pump and you should be good. However I do believe the switch tests every 3rd vehicle. One will be strictly under hood emission for 3 cars then for fuel system for 3 and exhaust for another 3. I have seen them do all 3 tests on one vehicle as well.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
