steering wheel upside down - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-05-2012, 08:54 PM
caprisecca caprisecca is offline
caprisecca is starting off with a positive reputation.
okay i have a 2001 sd crew cab ever since ive had it my steering wheel has been upside down. is there a easy way to make it right?
Old 08-05-2012, 10:26 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Yes, no and maybe. It all depends on the reason why it is upside down. There can be a few causes.
You need to take the truck to an alignment shop, have the truck aligned and have them correct the steering wheel.
Old 08-05-2012, 11:05 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Easiest way to recenter the steering wheel is to adjust the drag link. You can do this with it still attached to the pitman arm. A more precise and less frustrating way is to pop the drag link off the pitman arm, recenter the wheel, adjust the drag link so it fits exactly up to the pitman arm and reattach it to the arm.
Like Redford said either take it to a shop to find out why it was upside down or do a bit of inspection of your own. It could be someone replaced the steering box or some other steering component and never adjust the steering wheel. Or maybe something more foul is afoot.
04 steering gear issue chadjetlag 6.0L Power Stroke Diesel 0 06-15-2015 09:46 AM
83 Bronco: Loose steering wheel oblivionnewtonjohn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 01-20-2015 07:24 PM
lowboy F250 4" lift steering geometry NMFirstF2504X4 1973 - 1979 F-100 & Larger F-Series Trucks 30 02-05-2013 08:57 PM
Upside down steering wheel LSO1123 1999 - 2003 7.3L Power Stroke Diesel 6 06-08-2012 02:00 PM
Steering Wheel upside down? fredo181 1987 - 1996 F150 & Larger F-Series Trucks 8 08-02-2009 05:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
