Rear axle
There is a wealth of information hidden under the articles and specs tab at the very top of the page.
Here's just one of the articles that can be found there:
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
I'd first decide how you want to drive your truck and what engine/tranny you might be using to better zero in on what gear ratio you might want, then see what years and models had gears in the right range. It will be much easier and cheaper to buy an axle with the right gears in it even if you need to change the mounts. Also what you are planning on doing with the front axle will make a difference if you want the wheel stud patterns to match so you don't have to mix and match wheels/carry two spare tires. There is absolutely nothing wrong with using the stock front axle and brakes, they work just fine once rebuilt, but if you must go with IFS the bolt pattern isn't likely to match.
Here,s a link about rear axle. Hope this helps.
In many vehicles the engine, driveshaft and rear axle are offset to the pass side to give the driver more foot room. It doesn't matter if you use an offset axle with a centered or even driver's side engine offset, the U joints will make it work just fine as long as the engine and tranny are parallel to the chassis centerline (in other words don't point the engine/tranny at the offset pinion). If fact the engine/tranny/driveshaft/rear axle should never be in a perfectly straight line.
john jamieson
11-28-2015 09:39 PM
1949 F6
13
09-13-2011 06:13 PM
