Should I?
#61
When i questioned about the welding for a SAS, i was wondering what needed to be welded. Unless you were converting from coil to leaf in the front i think the only thing missing is the appropriate shock mount locations. I can't be sure though.
#62
Well this bronco is my daily driver with a little offeoad and towing. I just dont want to constantly have alignment issues. Ive been reading up bout coil vs leaf and everyone is saying coil or spring. I already got this used procomp lift. If i do the sas swap with coils. I dont think i can use them coils. Idk bout the extended radius arma i have either.
#63
The radius arms would need some major fabrication to work, as for the coils there is a little to be done there also. TTB can usually stay true with 35's or less. If you think you will eventually go to the SAS then sell what you have and save for the straight axle. I see Dana44's in the junkyards all the time. A dana60 is a little tougher to find but they're out there.
#66
#70
#73
I've been gone all week, just reading up on Manfred's lift project. I'm glad to see some info on the 250 hanger. I've heard they could be used as a shackle kit. The ttb front end should be able to handle 6" and 35x12.50 ok. Any bigger a sas should be considered. As far as towing, all that would be on the rear end, right? For the front end, any corrections can be done through the caster/camber adjusters?
#74
Well I've been thinking.
I probably will lift the Bronco using the TTB. I've found some 6" shackle flips for $195 shipped.
I would do the SAS but I need the tools and area to do it...something I currently don't have. Plus I already got this TTB lift. PLUS I don't have a Dana 60 yet for my 79 to replace the 44 with.
Someone told me to flip my tierod ends on my front end once I lift my TTB.
Dkosct
07-10-2016 08:06 PM
