front locker or L/S units
on
What locker or limited slip have you guys found that work good in the front axle? It is a f250 reg cab. Is a detroit alright in the front or should I do a good limited slip. It is a heavy truck running super swampers and a 4" lift and a auto. Detroit or powr lock or trutrac, what have you guys had good luck with and bad luck with?
you have a 60 or a 44?? some people say a lock right, especially on a 44, with big tires, can damage the carrier, has to do with the way they work. Lots of people run them without issue. Obviously if you are chaging carriers anyway no reason not to go to a carrier replacement style limited slip like the detroit or other. Personally I don't think I'd put a detroit in the front just because of how harsh the engagement is. The truetrac looks like its a true limited slip so it should be less harsh. Idk. what do you do with the truck? If you want to use 4hi like in winter you may want a selectable locker.
351Cleveland C4
07-06-2014 06:51 PM
operator exmark
07-24-2007 07:21 PM
