front locker or L/S units - Ford Truck Enthusiasts Forums
Old 08-05-2012, 10:11 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
What locker or limited slip have you guys found that work good in the front axle? It is a f250 reg cab. Is a detroit alright in the front or should I do a good limited slip. It is a heavy truck running super swampers and a 4" lift and a auto. Detroit or powr lock or trutrac, what have you guys had good luck with and bad luck with?
Old 08-05-2012, 11:23 PM
biggirlf250 biggirlf250 is offline
biggirlf250 is starting off with a positive reputation.
I ran a lock right in the front of my '77 f250 with 38 boggers, never had a problem with it, I'be swapped the front different. To a 60 now and its welded no issues with that either
Old 08-11-2012, 11:09 PM
I am going to need a different cqrrier or a thick cut gear and i was thinking that to swap carriers I would buy a L/S unit for the front. Like a Powr lock or trac lock.
Old 08-11-2012, 11:12 PM
Quote:
What front diff. Are you running?
Old 08-12-2012, 10:09 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
you have a 60 or a 44?? some people say a lock right, especially on a 44, with big tires, can damage the carrier, has to do with the way they work. Lots of people run them without issue. Obviously if you are chaging carriers anyway no reason not to go to a carrier replacement style limited slip like the detroit or other. Personally I don't think I'd put a detroit in the front just because of how harsh the engagement is. The truetrac looks like its a true limited slip so it should be less harsh. Idk. what do you do with the truck? If you want to use 4hi like in winter you may want a selectable locker.
Old 08-13-2012, 08:27 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Quote:
The lockrite is no sweetheart either. I personally love the rear locker-front limited slip combo.
Old 08-13-2012, 10:28 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Stay far away from a tru-trac, they are junk. I have a Powr-loc in my front 60 and as far as i'm concerened it's the best choice. It always turns both tires, has no bad manners and you can't feel a thing even it tight turns locked in.
Old 08-13-2012, 11:37 AM
scott79's Avatar
scott79 scott79 is offline
scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.
Depends on what you are trying to achieve, off-roading or simply pulling...? But, like the previous poster said, your best set-up option is powr-loc in a d60.
Old 08-13-2012, 12:01 PM
vic_v8 vic_v8 is offline
vic_v8 is starting off with a positive reputation.
I had my 60 welded because the only time it sees 4x4 is off road.
Locker Opinions for a 4wd Diesel Tow Rig roycec 1987 - 1996 F150 & Larger F-Series Trucks 14 03-09-2015 10:28 AM
Differential Equations 61steven 1973 - 1979 F-100 & Larger F-Series Trucks 31 02-03-2014 03:01 PM
2012 4wd SD F250 King Ranch PtownBubba88 1999 to 2016 Super Duty 11 01-13-2013 07:41 PM
Detroit locker install question Bird Hunter 1994.5 - 1997 7.3L Power Stroke Diesel 23 10-01-2012 01:14 PM
F-250 limited slip junk, what do i get 4x41977 Clutch, Transmission, Differential, Axle & Transfer Case 6 02-02-2009 03:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
