"trailer wiring fault" code on dash - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-05-2012, 09:28 AM
redbull660's Avatar
redbull660 redbull660 is offline
redbull660 is starting off with a positive reputation.
I have a 2008 f350, once and a while I will get a message on the dash display that will say "trailer wiring fault". It will do this whether Im hooked to a trailer or not. If I hook it to a trailer all the lights and brakes work fine. I do notice that when hitting the brakes when hooked to a trailer it doesnt show any brake gain on the display on the dash, it always shows "0" but the brakes work. Ive checked the plug and everything seems to look fine. Any ideas, thanks.
Old 08-07-2012, 05:58 AM
aburns20 aburns20 is offline
aburns20 is starting off with a positive reputation.
There was a post on the trailer lights that I read yesterday that is somewhat similar to this. I saw something like this a few weeks ago when I was towing my RV, I had trailer running lights but no brake lights or turn signals and no trailer gain. Found the trailer light fuse burnt out yesterday.
Old 08-07-2012, 06:27 AM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Quad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to all
Mine does this too. As long as everything works I let it go.I dont tow anything all that heavy though.
And yes there is a good thread on this in here somewhere.
Old 08-07-2012, 06:33 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
This thread has some good ideas in it, some more difficult to troubleshoot than others, but it's a start:
http://www.ford-trucks.com/forums/63...t-message.html
Old 08-11-2012, 09:17 AM
Pete0415 Pete0415 is offline
Pete0415 is starting off with a positive reputation.
I had this happen to my truck . I took it to the dealer and they said water had gotten it to the hitch plug wiring and it will send a fault code.They blew out all the connection and just put some electrical grease on the connections . Have not had anymore problems since then and it has been about a year now. Hope this helps you guys.
Old 08-11-2012, 11:58 AM
redbull660's Avatar
Thanks I will give it a try.
2006 F-350 Intigrated TBC problem SolarKing 1999 to 2016 Super Duty 5 04-28-2016 03:12 PM
TBC fault emmagator 6.0L Power Stroke Diesel 7 05-23-2013 04:02 PM
1997 F-250 HD Trailer Brake connector location? bigsbetter11 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2013 08:04 AM
TBC Fault Code need help mrw1 1999 to 2016 Super Duty 1 01-01-2012 07:11 PM
" Wiring Fault On Trailer " or " Trailer Disconnected " on Message Display F250SD-08 1999 to 2016 Super Duty 10 03-18-2011 03:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
