Lucille had an engine venting problem, finally fixed it today.
Lucille's previous owner had installed a sbc 307 (from a '73 camaro) in her and thought it would look cool with a set of 283 unvented valve covers. The older 283's used an oil filler (on the intake) with a vented cap (which she had) and a rear draft tube vent that went behind the engine and vented under the vehicle. The po didn't have this on the engine since the 307 originally used a vented valve cover with a pcv valve which pulled the crankcase engine pressure out through the intake (specifically the carburator vacuum line at the base of the carb). Lucille's set up made the vented oil filler cap an oily stinky mess which also made the cab smell like hot motor oil all the time. To remedy this, I ended up replacing the valve covers (with a vented set), used a t-connector from the vacuum line behind the carb for both the crankcase vent (pcv valve) and the brake booster, then slapped a vented oil cap on the other valve cover. I replaced the oil filler tube (on the manifold) with a freeze plug and painted it with a rattle can. Seems to be working fine now without the stink and oily mess. While I was at it, I replaced the air cleaner, removed and cleaned the carburator, repainted the intake, replaced the fuel line (cleaned the glass style fuel filter), and repainted the alternator bracket matte black. Pics below.
Wally
1951 F1 - "Lucille"
Wally
1951 F1 - "Lucille"
Thanks Rob, here's how she looked under the hood when i bought her last fall. I've spent a ton of time getting everything in order, very therapeutic.
Wally
1951 F1 - "Lucille'
Wally
1951 F1 - "Lucille'
JGreen236
11-01-2020 05:08 PM
Joshua Christopher
01-25-2017 07:23 PM
akuhr93'f150
09-18-2014 10:07 PM
1925mosin
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-07-2012 11:04 PM
