whining/grinding noise when accelerating - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-04-2012, 10:17 PM
Robtony20's Avatar
Robtony20 Robtony20 is offline
Robtony20 is starting off with a positive reputation.
I have a '04 Expedition EB and starting noticing a slight whining noise a few days ago when I accelerated from a full stop or getting up to "in town" speed. I have read several posts on here and majority seem to be around cold weather but that certainly doesn't apply in my case, it's the beginning of August and on average about 90 degrees outside. It sounds similar to a whining power steering pump but when I checked the pump and fluid levels it all looks good. I continued to check all the other fluids(trans, oil, brake) and they all look good too. My family and I went on a bit of a lengthy roadtrip today and it stayed about the same until we were on our way home and I thought I heard a sort of "rattle" when I turned a corner, went several miles and never heard it again until I came up to a stop sign and began to accelerate. That slight rattle I heard earlier suddenly seemed to become a big rattle and the truck didn't seem to accelerate like normal, almost seemed like it had to work a lil harder to get going at first. Once I hit 60 kmph or 40 mph and the transmission shifted the "rattle" seemed to go away but could still hear a bit of a "whine". When we got home I popped the hood and checked all fluids and all were good, started the truck and listened and a similar whining noise seems to be coming from under the plastic cover on top of the motor but I can't say foresure. I'm hoping it's not a transmission issue as we all know they are never cheap fixes. Any suggestions or diagnoses would be greatly appreciated.
E4OD Now Whining Loudly; Previously Returning to Neutral Eratically The Harvester 1987 - 1996 F150 & Larger F-Series Trucks 3 02-01-2014 07:00 PM
Fix for Power Steering Whining? Halloran1 1987 - 1996 F150 & Larger F-Series Trucks 20 03-22-2012 10:24 PM
2003 Expedition 2WD Transmission Whine/grind dstrahm 1997-2006 Expedition & Navigator 3 08-26-2011 06:50 PM
Hydro boost whining noise, might be fixed. secakc 6.0L Power Stroke Diesel 6 02-28-2011 04:36 PM
Identifying Front Pump Whine vs. Power Steering Whine 5.4L to Freedom 1999 to 2016 Super Duty 4 12-16-2010 06:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
