Cruise installed
Old 08-02-2012, 08:19 PM
mytbtruck's Avatar
mytbtruck
mytbtruck is offline
Cruise installed
I have been working on installing cruise for some time off and on and finally finished today and took a trial run. It works ok and I am glad it is finished. I removed the tab on the lever that was sticking up on the GM lever and painted over the wiper lettering. I think I will be well satisfied since I love to use cruise controls on all my other vehicles .
Old 08-02-2012, 08:42 PM
John Peterson's Avatar
John Peterson
John Peterson is offline
That could not have been easy ?How much hair did you pull out of your head ?
Old 08-02-2012, 08:55 PM
mytbtruck's Avatar
mytbtruck
Hair, whats that. I have been bald for about 20 years but is a good thought. I think the worst part was building enough confidence to try it out.
Old 08-03-2012, 06:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Years ago I installed a Rostra Cruise control unit on the 29 Ford pictured in my avatar. It's not a hard job if you do it at the time you wire the car and it sure comes in handy on those longer trips....
Old 08-03-2012, 07:33 AM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
Gary,
how 'bout some details. I purchased an Ididit column and got the cruise control added to the turn signal stick...
what did you use for controller and connections to carb ??? pictures would be sweet... I'd love to do this... like GNW said...it would be sweet on long trips. My longest trip so far is about 15 feet...from inside the garage to outside the garage. although, one time the frame did go a few miles on it's own for rear suspension fabrication
thanks
John
Old 08-03-2012, 07:56 AM
jbaysinger's Avatar
jbaysinger
jbaysinger is offline
Looks good.
Old 08-05-2012, 11:05 PM
mytbtruck's Avatar
mytbtruck
Originally Posted by jniolon
Gary,
thanks
John
I used the same one Vern used from Rostra. It was easy to install and very good instructions. I just worked on it a little at a time so it took me about two weeks to finish. I think they send you enough parts to connect it to almost any application. I only had to screw the bracket on the cable and clip the end on the throttle body and connect the two ends. The controller is a black box with the cable attached. It has 12 switches to fine tune it to your application. Can't get pictures to work tonight , maybe later. Larry.
Old 08-06-2012, 09:28 AM
mytbtruck's Avatar
mytbtruck
I am trying to post the picture of the hookup of the cruise on the throttle body. Hope it works.
Brian1950F4
11-09-2019 12:49 PM
Cru
1999 to 2016 Super Duty
05-04-2018 04:37 AM
Fleetsuper
05-04-2015 02:12 PM
bobj49f2
31
07-02-2008 01:24 AM
STUDENT
02-22-2007 05:15 AM
Quick Reply: Cruise installed
