Output shaft bushing now?
Along with my output shaft seal going bad again, my new center support bearing was also bad. Today when i took it to my driveline guy, we noticed that the slip yoke is worn pretty heavily. He said that theres a brass bushing inside the transfer case where the slip yoke goes into that is most likely bad, and that I should have the slip yoke and the bushing replaced. Can you guys shed any light on this bushing? Or at least what its called so i can look up a price?
on
1 Post
I found this Rob, I think it's the right bushing.Bushing Rear Output Shaft
Here's an exploded view and parts list also Borg Warner 1356 Transfer Case Mechanical Shift - Rockland Standard Gear, Inc.
Freightrain
12-23-2013 04:09 PM
beeboy
09-17-2003 11:35 AM
