Tow/Haul when not towing?
I use it regularly. Mostly in traffic and anytime I'm not on the highway. As mentioned above, it saves a lot on braking, and acceleration is much more enjoyable since it holds gears longer (where it should be, in my opinion.) I can't stand how the new tranny programming upshifts so early. I mean 6th gear at 40 mph?????....that's way too early.
I believe that there was a post on here about this same issue. I am unable to find it. There is a gentleman on here whos name is mark. In his discriptures it states that he was/is a certified ford transmission mechanic for 20 years or so.
If I remember correctly (I am getting older so things are fuzzy now and then), He said to leave it on dont mess with it, that is what its designed for.
I would prefer to have a warped brake rotor than to have a warped trans for playing with it all the time. Just my opinion.
Not really - the TorqShift transmission is totally different than the 4r100 in older trucks, much more advanced than just turning OD on and off. It's talks a lot w/ the PCM and activating the tow/haul feature changes the shift points as well as activating engine braking.
No, it's totally different. OD OFF prevents the trans from shifting to overdrive gear. Tow/haul does not prevent overdrive. It changes the shift pattern to make all the upshifts at a higher speed and also provides automatic downshifts with engine braking. OD OFF doesn't do that.
Whatever it does - it is a GREAT tranny that i personally LOVE that it gets into taller gears quickly when possible...
and can use tow haul just for slowing down rather than wearing out my non warranted brakes faster - the 5er does that enough already !!!
all three of my Ex's would be in lower gears at high rpms while on this long 30 and 40 mph 2 lane to the highway from the house.. In the early mornings I wanted quiet on the ride into work - not high rpms and straining engine
So I used to speed up to 42 mph and let off so it WOULD upshift and be quiet for a while until the next rise
the new tranny is the best so far... let's me do what I want to do WHEN I want to do it!
(at least to a point of not lugging or over reving !)
