So who makes the best lift kit? - Ford Truck Enthusiasts Forums
Old 08-03-2012, 07:26 AM
First Ford 2004 First Ford 2004 is offline
First Ford 2004 is starting off with a positive reputation.
I wanna put about a 4-5 inch lift and I wanna put a good kit in that rides great any suggestions and why thanks
Old 08-07-2012, 11:37 PM
Right on guess Ill get that one
Old 08-08-2012, 06:01 PM
ComputerCowboy's Avatar
ComputerCowboy ComputerCowboy is offline
ComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to behold
Absolute best would be Kelderman probably. Best reasonable priced kit is BDS... If you want it to ride nice you'd better get the Fox shocks, the BDS shocks are really harsh.
Old 08-08-2012, 06:12 PM
96grimreaper's Avatar
96grimreaper 96grimreaper is offline
96grimreaper has a very good reputation on FTE.96grimreaper has a very good reputation on FTE.96grimreaper has a very good reputation on FTE.96grimreaper has a very good reputation on FTE.
Quote:
Agreed. I'll be replacing my BDS shocks with FOX when the time comes.
Old 08-09-2012, 01:46 PM
Thanks for the advice
Old 09-12-2012, 10:40 PM
I dont wanna spend kelderman kinda money on my ex but just wanted to double check with everyone on there ride and lift kit. Thanks for the advice I wanna get the best possible ride out of my excursion.
Old 09-13-2012, 07:09 AM
Atc210 Atc210 is offline
Atc210 is gaining momentum as a positive member of FTE.Atc210 is gaining momentum as a positive member of FTE.
Rough Country makes a good one that is affordable. I dont own it yet, but have rode in a few that have installed them. Either way no matter what you go with will be a improvement over the factory ride, IMO.
Ford Suspension Lift Kit
Old 09-13-2012, 08:56 AM
Jarhead97's Avatar
Jarhead97 Jarhead97 is offline
Jarhead97 is gaining momentum as a positive member of FTE.Jarhead97 is gaining momentum as a positive member of FTE.
My X is the 7th lifted truck/SUV I've owned and this is the first time I've run a BDS lift. Very happy with it and would put it up at the top for overall quality and ride quality.
Good point on the Fox shocks. I'm running the Fox 2.0 dual shocks up front, but the BDS shocks in the rear. Once the Fox 2.0 is available for the rear I'll be upgrading.
Old 09-13-2012, 01:48 PM
X-Hibition's Avatar
X-Hibition X-Hibition is offline
X-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to all
If you like the idea of no blocks on the rear then go with the Icon all spring kit. Many are not fans of the rear blocks. If you want to save money then install truck springs for more lift and less money.
It's your choice.
Old 09-13-2012, 02:35 PM
Mattb60 Mattb60 is offline
Mattb60 is starting off with a positive reputation.
Just did the Rough Country 5"
Very happy thus far. Rides well. I did not have any issues with steering wander prior to the lift and this continues to be the case. No vibrations or other unexpected surprises.
Old 09-15-2012, 01:05 PM
Landbarg Landbarg is offline
Landbarg is starting off with a positive reputation.
Matt, I am eyeing up the RC lift as well. I'm just concerned about the lift blocks for the rear. Seems a bit much. Too much potential energy there to tweak to the side. I would at least install a rear track bar to keep things straight. That's what I am considering. I haven't really looked for one for the Ex, but I can make one in my shop with heavy guage pipe and some heim joints from the race shop.
At any rate, let me know how it rides after a while. Really interested in seeing what the long term viability of this kit is. Thanks!
Old 09-15-2012, 06:46 PM
Will keep you posted.
This is my first lifted truck, so I can't comment much on the viability of the rear blocks.
I saw several positive reviews of it on other threads and it was recommended to me by the shop that installed it. The guy who did it said that he has had good success with the Heckthorn/R.C. On Exs. Specifically noted that it is one of the few that is made for Ex and that the anti-wrap setup for the rear axle is good.
So far so good.
Right now I have a lifted Ex rollin on p265s, but my wheels should be in this week and we can see how the new shoes fit under the lift
I will learn to post pics at some point and show some before and after
Old 09-15-2012, 09:15 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Your X stock?
If so, Ford makes the best kit IMO. The springs for a Superduty typically give guys 3-4" of space. Add some longer shackles and an adjustable track bar if you can fit 35's on that alone.
Most aftermarket stuff doesn't ride as nicely as stock unless you spendcsome crazy $$$.
If you do aftermarket, my suggestion is Icon.
Old 09-15-2012, 10:05 PM
Thanks Matt I appreciate it!
Lift kits David Fehir 1999 to 2016 Super Duty 17 02-08-2016 09:19 PM
Sky Manufacturing? Gasquatch 1987 - 1996 F150 & Larger F-Series Trucks 8 10-24-2015 10:07 AM
flip shackle kit gitrdone69 Offroad & 4x4 1 01-16-2015 05:49 AM
Have 1980 F100 and wondering bout a lift kit jschne52 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-18-2011 07:39 PM
What kinda lift for 35s? 03 4wd supercrew 98infinity 1997 - 2003 F150 23 04-23-2007 10:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
