09 Exped EB- rough idle fixed - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-03-2012, 03:51 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
Well I finally got my Exped repaired.
It took a 24hr road trip (6hr there, work time then 6hrs back) to get everything fixed...but it was free so we couldn't complain. Joe Watt Auto (where the SO bought our rigs) did all the work and bought me a hotel room so I could sleep while they worked.
Turns out on the pass side, the spring that the truck uses for the variable cam timing failed so stuff was flopping around and causing the motor to be out of time w/itself (periodically) which was causing all the clunking/clanking/rough idle/CEL/flashing CEL/etc.
They went ahead and replaced timing chains while they were in there too.
Maybe this will help someone else fix their issues.
99 ford f350 7.3l Feonix1123 1999 - 2003 7.3L Power Stroke Diesel 65 04-28-2013 10:39 PM
Can't boost over 20 lbss, low pressure and coolant doesn't get hot vpnwiz 6.4L Power Stroke Diesel 7 04-09-2012 10:37 AM
Holiday weekend help? p0305 cyclinder 5 misfire, p0506 idle air below specs waterman74 Expedition & Navigator 3 07-03-2011 03:17 PM
01 4.6 Persistant #3 misfire. BioBurner Expedition & Navigator 10 02-23-2011 10:38 PM
Update on EGR bypass hl649 Ford Inline Six, 200, 250, 4.9L / 300 15 09-24-2002 10:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
