1952 Ford F-8 - Page 2 - Ford Truck Enthusiasts Forums
1952 Ford F-8
Old 09-25-2013, 05:48 AM
big job's Avatar
big job big job is online now
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Very very nice work. Its nice to do a new truck. Most people dont have that
roayalty. One question, where in the world did you get the side ways spin on
oil filter. I've been looking for years and cant find one. That allows using a
two quart filter. Your choice but I would put a dump body rather a flat bed,
they are way more versatal. Most of mine are 9 foot 7yd you can put 10yds
and then I built a (box) goes in the side boards, with barn doors so it doubles
as a van, I covered this with 4x8 sheets tin, and looks like factory. Why? we are
adding on the shop, truck goes to Home Depot gets lumber, lumber stays in
dump truck / van, high and dry. barn doors closed all locked up. When I dont
need it, simply pluck it off, and back hauling gravel again. Too bad I cant put
pics in threads like other forums.
Excellent work
Sam
Old 09-25-2013, 10:10 AM
pilot31's Avatar
pilot31 pilot31 is offline
pilot31 is gaining momentum as a positive member of FTE.pilot31 is gaining momentum as a positive member of FTE.
Thanks for all the positive comments everyone.
As far as the e-brake band being painted... Darn right!! LOL even though I won't drive this truck in the salt and snow, it is a harsh climate here. Everything will be protected as best I can from the elements. The parking brake drum is powder-coated!
As far as the oil filter swing. Yeah that is a nice feature. That was installed before I got the truck. I plan on putting a remote oil filter onto that. The ram horns exhaust I put on might be a bit close to the filter. I'll make the final determination on that down the road.
I would google 1957 lincoln spin on oil filter, as that was the first year they offered a spin on. Then when you find the part number for that, look for one on evil bay or something. They are all lincoln y blocks so they should fit. However that being said I'm not an expert.... ask around somebody has to know for sure.
I'm guessing being Ford, you could probably get one from summit racing or something....
Old 09-27-2013, 06:16 PM
pilot31's Avatar
Old 09-27-2013, 06:31 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
That's a great looking F8 and very good work you have done!
Old 09-27-2013, 07:33 PM
pilot31's Avatar
Thank you for the positive comments. It is a very low mileage, great running former fire truck. Being a fire truck it spent most of its life inside. Good part is now that there is paint on the entire cab, I can actually start putting it back together!!
Old 06-04-2014, 05:32 PM
pilot31's Avatar
A continued bit of progress....
Old 06-04-2014, 05:43 PM
pilot31's Avatar
Wink
I forgot to post a picture of my Valve covers and new decals..
Old 06-04-2014, 06:50 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Looking good!
Old 06-06-2014, 12:46 AM
C-700 C-700 is offline
C-700 is starting off with a positive reputation.
Quote:
Nice to see the engine the original color. What transmission are you running?
Old 06-06-2014, 01:51 AM
1952henry's Avatar
1952henry 1952henry is offline
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
I like your attention to detail.
Old 07-04-2014, 02:09 PM
pilot31's Avatar
Thanks everybody for the nice comments.
As to one question asked, I have the clark 5 speed direct drive tranny with a 2 speed rear.
Here is my before, and after of the door panel for the five star cab....
1952 Ford F-8 volume 2 by pilot31 Picture 1543802 - Ford-Trucks
And the after....
1952 Ford F-8 volume 2 by pilot31 Picture 1543803 - Ford-Trucks
Old 07-04-2014, 02:43 PM
Chicago Fire Patrol's Avatar
Chicago Fire Patrol Chicago Fire Patrol is offline
Chicago Fire Patrol has a great reputation on FTE.Chicago Fire Patrol has a great reputation on FTE.Chicago Fire Patrol has a great reputation on FTE.Chicago Fire Patrol has a great reputation on FTE.
Nice work!! Beautiful truck.
  #28
Old 07-04-2014, 03:36 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is online now
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Looking good!
Where did you get those cab handles? Those would sure make it easier to get into the truck.
They look like these...
Amazon.com: Transdapt 9700 CHRM 12"" CAB HANDLES (PR)": Automotive Amazon.com: Transdapt 9700 CHRM 12"" CAB HANDLES (PR)": Automotive
  #29
Old 07-06-2014, 05:51 PM
pilot31's Avatar
Door handles/grab handles came from LMC truck. They come as a set for approximately $30.
I think that's very reasonable, considering your less apt to wear out your seat getting in and out of the truck
Part number is 38-1941.
I did not use the screws that came with them. I used stainless bolts with nice thick washers and by lock nuts to spread the pressure on the cab so as not to distort the metal.
  #30
Old 07-06-2014, 06:19 PM
Just another Joe
Thanks, I added them to my list.
what is this farmer ford 1994.5 - 1997 7.3L Power Stroke Diesel 2 02-25-2012 01:02 PM
1995 F350 7.5L - Can Anyone Identify This Part? cougarman001 1987 - 1996 F150 & Larger F-Series Trucks 5 01-22-2012 08:01 AM
65 back together StevenhF100 1961 - 1966 F-100 & Larger F-Series Trucks 16 11-08-2010 07:00 PM
What Turbo is this? Rubidon 1999 - 2003 7.3L Power Stroke Diesel 10 06-28-2010 09:45 PM
Big Block Problems............------- MikeyLikesIt Oregon Chapter 40 04-12-2009 01:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
