Retrofitting Camshaft set up questions?
Old 08-02-2012, 08:50 AM
chamblizi's Avatar
chamblizi
chamblizi is offline
Yo, Phil here i got some questions about retrofitting a 400 CID for a hydraulic roller cam, what are the differances between A regular set up and a hydraulic roller cam set up "Besides no break in,"Pros and cons.
Old 08-13-2012, 04:25 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
With the rollers, they are less likely to have excessive wear/damage on startup, but that's about it. Roller do have an advantage in they can typically turn higher rpm with less valvetrain mods, you can also run a higher duration as the roller is more relaxed/take a higher duration without affecting idle quality/vacume levels at the low end as much- basically more forgiving (with hydraulic liters)
Old 08-15-2012, 09:58 PM
chamblizi's Avatar
chamblizi
whats a good balance for a prodominatly stock engine?
Old 08-16-2012, 06:08 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
duration, 280 to 290 range, lift max around 500-520- that would be with a roller, if not, just stick to the lower range of those numbers and it would still be a very nice engine.
Old 08-16-2012, 07:20 PM
chamblizi's Avatar
chamblizi
right on man right on.
rusty70f100
10-12-2005 09:59 PM
debestuss
22
08-04-2005 09:31 AM
fatdaddy
12-28-2001 04:52 PM
thenkel2
03-27-2001 03:36 PM
bigsnag
17
03-07-2001 06:48 AM
Quick Reply: Retrofitting Camshaft set up questions?
