You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Yo, Phil here i got some questions about retrofitting a 400 CID for a hydraulic roller cam, what are the differances between A regular set up and a hydraulic roller cam set up "Besides no break in,"Pros and cons.
__________________
"I'll learn my self, where is my beer!"
With the rollers, they are less likely to have excessive wear/damage on startup, but that's about it. Roller do have an advantage in they can typically turn higher rpm with less valvetrain mods, you can also run a higher duration as the roller is more relaxed/take a higher duration without affecting idle quality/vacume levels at the low end as much- basically more forgiving (with hydraulic liters)
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
whats a good balance for a prodominatly stock engine?
__________________
duration, 280 to 290 range, lift max around 500-520- that would be with a roller, if not, just stick to the lower range of those numbers and it would still be a very nice engine.
__________________
right on man right on.
__________________
