Changing serpentine belt..how much coolant do I lose?
I have a 2000 7.3 with the hose through the belt. My current belt is cracked on the ribs and missing some edging, so I'm replacing it before it breaks. I bought the belt at the local Ford dealership and have it now.
At this point in time, I think I will just retain the stock hose, I did read up on the NAPA 9066 etc.
How much coolant is lost if you just pull the rad hose off at the radiator long enough to swap the belts assuming old belt is off the pulleys? (hopefully seconds)
My other (neater) plan is to drain some coolant from the rad into a clean jug and squeeze the top rad hose to empty some of the coolant out that way before disconnecting the hose.
How much coolant do I need to drain from the rad if I do it this way?
Figure I'd ask since someone here has done this before and I'll be damned if I can find the answer using "search"
This is how I'd do it. You may have to drain a few gallons out of the petcock. After that, you should not lose much of anything if you disconnect the hose on the radiator side. Then you can just pour you cooant back in the degas bottle.
Thanks everyone. I will definetely be draining the rad down using the petcock and pouring the coolant back in the degas when done.
The only reason I was shying away from the 9066 was the higher risk of the hose hitting the belt (need to cable tie in place) and it appears the powersteering filler is harder to get to with that hose.
I will price the 9066, I'm in Canada so it's probably more $$$.
Just a side note guys: I installed a Dieselsite coolant filter setup-(very nice setup) and the around the belt hose on my LATE '99 and the hose rubbed the filter itself enough that I changed back to the through the belt hose-I've got a 1/4" clearance now-I don't like stuff like hoses rubbing even on anything smooth like a filter.
1994F2507.3L
01-12-2011 12:15 AM
