vapor locking '68 300 il 6
J Welcome to FTE and the Bump Forum.
Vapor locking is a term from bygone years, I suspect you have a different problem with delivery. Have you changed filters, checked for trash blockages etc.?
Pull your gas line near the carb, along with the coil wire. Put the gas line into a clear empty water bottle, and have someone spin the engine over while watching the gas flow.
You may very well have a small piece of rust blocking the flow, the pump may need replacing.
John
John
vapor locking
J62, Does your exhaust manifold have heat riser butterfly . If so make sure that it is free to move. If it has one and is frozen closed it will cause the fuel to boil in the carburetor. One other thing to try if in fact that heat is causing the problem I have seen someone fashion a piece of aluminum as large as possible as a heat shield between the carburetor and manifold. Many years ago I saw a small electric fan mounted to blow air on the carburetor of a Datsun B210 that was factory installed! What type fo air cleaner are you using? Is it the one with the snorkle and butterfly that is operated by a small thermostat ? I have seen a lot of 300 s that have exhaust leaks between the head and manifold or between the intake and exhaust manifold where they are bolted together. My brain is empty now.
Kenny
Kenny
jimstrecker
08-31-2007 05:48 PM
